3.3 engine?
Toolman
Boost it!
Grand Lake, Oklahoma, USA
John M's (California based build, think a white 91+ 91+ ?) JEM on this list. The custom gasket maker he hired did not want to do another.
The 3.5 in my track sho is 92mm bore, the extra .3 comes by way of an offset ground and rechromed crank. 13:1 CR. Plan to Dyno with SHO manifold and then with Zach manifold. Compare the difference.
zak
east of Hartford
JEMs build was a 93.5 mm bore, same stroke as Hrinsin's build they used the same Honda sized rod journals.
Irish Pride
Irish Inside
MusicCityUSA
JEMs was actually a 3.6
The crank in his car was built at the same time and the same shop as the stroker crank in my 3.4.
-Chad
