TheJCamSHO
R1 drilled and slotted rotors with new pads.. have squeaked for the past 10k miles at least. Put around 20k miles on these new brakes. Now I’m getting brake shudder when I brake at freeway speeds (this is the reason I upgraded the rotors originally. Stock rotors we’re having shudder as well. That and wanted better stopping power). Shop says the brake pads could be touching rotor edges bc of improper machining regarding squealing (brakes will squeak a little while just driving, no braking also). Anyways I’m fed up. I have slammed brakes twice to avoid collisions (houston traffic is ******) which could possibly have warped rotors but I have a suspicion the brake hydraulic system may need to be flushed and fluid changed. My factory brakes had the same shaking issue after all. Could one machine rotors that are having shudder and restore smooth braking or do I need new rotors ? Any input is greatly appreciated.
