2012 Turbo Replacement
yaycandy
Aerospace Engineer
Hanover, PA
Thats crazy ass bad luck if out of nowhere both turbos stopped making boost. Just to perfect
jhardy1
Idaho
Just had the thought I should post the images from the 1st mechanic of the turbos leaking oil.
Car's at another mechanic right now doing the same investigation. Will post more updates later!
jhardy1
Idaho
Right? The car is 11 years old. It's gonna be a bit dirty under the engine
jhardy1
Idaho
Update: I'm about done with these "mechanics". 2nd guy noted that there is black smoke coming from exhaust because theirs "oil" in it. (First off I haven't noticed smoke in any quantity thats remotely alarming).
OFC Recommending the turbos be replaced.
Black smoke usually means you're running rich. HMMMMMM Wonder what a turbocharged engine with low boost would be running...
Anyway I'm gonna talk to the guy when he calls and see what he actually did. He said he couldn't find a boost leak, but we'll see if anything was actually done to check.
There does seem to be an actual leak from the oil return line, so at least he found something interesting
Ta2dResqr
Central Ohio
Has anyone done a leak test with a smoke machine? If the turbos are working but the motor is not getting boost, there should be a lot of smoke leaking that would be easy to find.
jhardy1
Idaho
Nope, these mechanics see oil and want to throw a new part at it.
Maybe I'll just go down to the local vape shop and have them blow into the intake for free
Ta2dResqr
Central Ohio
Not sure how much work you like to do yourself but, a smoke machine is $80-150 on Amazon. Most shops labor rate is in the same ballpark. Buy the machine and you have the tool when you are done or sell it on Marketplace/eBay.
jhardy1
Idaho
Might do that. I'm planning on checking the wategates later today for missing clips, bad hoses, and actuation. I bought a hand pump vacuum/pressure tester thar should be here later today
toms89
Bad hose to the wastegate should cause overboost because it would not get the "boosted" air necessary to open the wastegate. Now if the C-clip comes off the end of the rod the wastegate could flap open freely if the rod detaches from the wastegate lever. There would be no preload from the wastegate canister to keep it closed.
As you apply pressure to the wastegate canister via your tester you should see the wastegate open. Should start moving around 6 to 8 psi I believe.
You could pull the intake hose (center of compressor housing) off of each turbo so that you may reach the compressor wheel and see if they feel like they spin freely, do not have excessive play, not seized up or otherwise broken.
jhardy1
Idaho
So I removed the air box to try to get a better look at the front turbo, this connector was hanging not connected to anything. What is it
jhardy1
Idaho
How do yall get access to the wastegates? I can barely see the shaft on the front one. Remove exhaust manifold cover?
It's becoming clear I'll have to go under to inspect the rear turbo in any way.
Also, why does the rear turbo have 2 bovs before it reaches the intercooler but the front turbo doesn't have any?
toms89
I attached my vacuum / boost gauge to the line leading to the wastegates from the boost solenoid. As I applied pressure I could see the rods moving on both from above with a flashlight. To see the c-clips you would have to be under the car.
jhardy1
Idaho
I can't see my rear turbo actuator at all, guess I'll have to look harder
toms89
Once you figure out where it is you can see it. I think I actually stuck my hand down there and could feel them move as well.
I found it interesting that both bypass valves are located where they are as well. Probably just a matter of packaging. Since it is a one common pressurized system I guess it works regardless.
jhardy1
Idaho
Ah OK I see it on mine now. Thanks!
Pulled a spark plug, looks like it's seen better days. Probably needs new ones eh
jhardy1
Idaho
Also measured the voltage going to the boost solenoid. 10.5V normal?
Just popped a p0193, fuel pressure sensor high reading.
Wtf
