2012 Turbo Replacement
toms89
Also measured the voltage going to the boost solenoid. 10.5V normal?
Just popped a p0193, fuel pressure sensor high reading.
Wtf
If the boost solenoid did not function the car should default to wastegate pressure. Maybe 6 to 8 psi boost ?? The boost solenoid shuts off the wastegate boost lines in effect building more boost because the wastegate will not open. So if it fails, theoretically you either get max boost or wastegate boost pressure. I don't think it would be zero.
jhardy1
Idaho
Well good news! Wastegates actuate normally to my untrained eye when pressurized to 8 psi
jhardy1
Idaho
If I go under the car is it pretty easy to take off the intake side hose to check out the compressor/shaft?
jhardy1
Idaho
Final update: went under the car to check out the front turbo. Shaft has A LOT of play and the compressor fins are banged up a bit. She's ******
