Angrymongoose
Omaha
New connector/pigtail came in, gave the wiring a shot. No dice.
Thankfully amazons replacement policy will get me a new unit entirely. Should be here Thursday or Friday. This time Im gonna double check that it works before bothering to run wiring through the wiper grommet.
Nova
US
Well tonight I just received a picture of my steering wheel and shifter I see a couple mistakes that they did wrong with being colored wrong. we'll see what they say but still looks pretty damn good what do you think...
Looks great!! You're going to need to wear white gloves every time you get in your car so you don't get that wheel dirty.
limited02
Olathe, KS
Torrential downpour + trying to be fast = forgetting to put car in park...
Came out and noticed my car wasn't were I left it.
6EF67207 5330 4042 B9AA B7F7CB3321FC
342DBB33 0F0F 4FBE 84E5 B65E664996B5
Got home and it snapped back in place! There's a little scuffing, but as my FIL always says, "No one will notice on a passing horse."
F4483A86 DCB2 4C10 9F28 59640537BC26
I'm going to check the dash cam tomorrow to see if it captured it.
limited02
Olathe, KS
That had to make you feel like a dumb dumb. ^
Glad you got it patched up easily. It’ll buff out.
Felt like a dumb dumb indeed and not to mention, my first "wreck." I'll hit it with the polisher later today to see how it comes out.
jman1200
Ontario
I've always used the parking brake, even when I park inside my own garage... this is just another reason to use it.
That bumper will most likely show deformation marks after its pulled out requiring paint. Still not something I'd put through insurance.
You were millimeters away from breaking your headlight. That was lucky.
limited02
Olathe, KS
Luckily, the gal didn't care about it and we went on our separate ways. Since I was able to pop mine back in place, I can deal with how it looks at the moment. And yes, I lucked out because with my car having the EcoBoost Appearance Package, it's hard enough finding parts.
With those kind of bumpers it's best to use a heat gun while you pop it out
Agreed and I've done that before. I believe she mentioned her dad will take care of it.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
This is how we’re rolling around. 2” adapters :rofl:. It’s been a long time coming but finally got Jordan’s brakes on in the rear. Just need a helper to bleed the brakes, and we can mount the wheels up drop this thing back down to the ground. Then add about 350lbs of weights to it to simulate the engine is back in and mount the flares. 8B104D65 60A1 40D8 BEA3 6C20CFA6BC8C
Nova
US
This is how we’re rolling around. 2” adapters :rofl:. It’s been a long time coming but finally got Jordan’s brakes on in the rear. Just need a helper to bleed the brakes, and we can mount the wheels up drop this thing back down to the ground. Then add about 350lbs of weights to it to simulate the engine is back in and mount the flares. View attachment 18623
You and @Jordan_R are taking this weight reduction to the max!
Ashleycat
