Nova
US
Finished buttoning everything up with the splitter install this morning. Made some custom brackets for the splash guard to mount to the splitter with some aluminum flat bar I had in the garage. I also installed the rear carbon fiber lookalike diffuser too. I think everything came out looking pretty good.0b677c60af0ca6521db662a0c48743eb84b1563ee92b79ead39aec50ef13b82e4dbc561f05f34675076c9d2bd3d13ef6Aaf1e29f2d5f970da9653d6551f476f3Fc7c849a3ec97d0200d5399f5da3a93d16b4e39dc38b57eb9d39f62b340546702536915c3713734ad300a21c55236c61
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Nice! What about them splitter pics?? Holding out? Lol! No rush, but I’m subscribed to see more!
aaron240
Cambridge, Ohio
Looks good! And diffuser parts??? Are you making a custom diffuser?
Working on something from an rx7 universal kit, prob gonna modify and make it sho specific
Nova
US
Hmmm...sounds interesting, hopefully you can make it look better than what is pictured.
DadMobile
Texas
I replaced the Wilwood BP-20 pads with BP-10 pads Per Aaron’s suggestion and bedded them which has made a big difference already. Most of the squeal is gone so far!
After a couple decent stops I will get a loud squeal on the next stop but it’s pretty manageable. I only drove around for about 30 minutes and it was cold and rainy so the brakes were cooling down quickly.
Looks like the track will get rained out on Friday as well, damn!
The performance of the brakes is very noticeable over the stock brakes. I had new rotors and pads installed as a condition of but the SHO so the OEM stuff I had was good shape. The OEM setup just always felt lacking and had some crazy fade. The Wilwoods stop the car quickly with out noticeable fade.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
I drove it today...
doing some checks on the suspension tonight, swapping over to the XDI-60 pump, changing spark plugs and doing another check for boost leaks. yee haw
After I complete that I plan to take inventory of everything I have for the turbo swap to decide if I need to order anything else before I start that endeavor...
Jordan_R
Missouri
I drove it today...
Lemme know when I can come down and make that install money
