HOW-TO: Change plugs / Trying out Brisk spark plugs
Ecoboost_xsport
Sacramento, CA
This is sort of a how-to on how I do my plug changes as well as getting away from the FoMoCo SP-542 and trying out a different plug. It remains to be seen how well it will work out for me, but I will definitely keep you guys updated.
So on the advice of a pretty good local tuner, I decide to try out some Brisk spark plugs (Brisk Racing). There wasn't necessarily anything wrong with the 542s I was running, but with the power goals and modifications I am shooting for, I wanted to attempt one additional step colder of a plug (OEM was 534s, heat range 6, 542s are range 7) by going heat range 8 to see if I can squeeze some timing out of her. Although I have limited personal experience with Brisk, a lot of top shops and tuners use these things. I did some research and on the advice of that local tuner, decided on trying out the Silver Racing plugs (hey, it has Racing in the name, so it MUST be good, lol). They are heat range 8, which is 2 steps colder than OEM and it remains to be seen if I can get a bit more timing out of these or if they will just foul out. Oh, and they are Made in the USA so that's a plus, right?
First thing is getting those connectors off the coils. Slide back the red clip on the coil connector, it's easy enough with a small flat head screwdriver:
39GuurYj7mA8Lwidth1024height1024cropmodenone
0Ab8OzbaC LLywidth1024height1024cropmodenone
Then just press the clip retainer and slide off the connector. After disconnecting that, use an 8mm socket to remove the coil retaining bolt, then pull out the coil. Even though I only complete one cylinder at a time so as not to confuse things, I still typically mark the coil with a sharpie identifying which cylinder it came from.
Before you take out the old plug, it is important to use some air to blow out any debris that may be residing in that spark plug well so that it doesn't fall into the cylinder. You'd be surprised how much junk gets blown out of there, despite them being "sealed".
MuFRXCFMCJtW width1024height1024cropmodenone
After pulling the old spark plug, I look at the condition of it, mark it with a sharpie as well and I personally keep my old plugs for at least until the next plug change to compare them to the previous set. So they go in a zip lock and stored away.
 IW LpmIpNuGKwidth1024height1024cropmodenone
Here's the new plugs:
MZQMEw51dPSySwidth1024height1024cropmodenone
Side-by-side comparison:
20HAWEzJ4Pmmdwidth1024height1024cropmodenone
Tip/electrode difference:
9 M6gSrXjABuCwidth1024height1024cropmodenone
I had the SP-542s gapped to 0.26 and went with the same on the Brisk plugs.
M7ePs 6Yq 6Hrwidth1024height1024cropmodenone
5HKZhNBDTeOskwidth1024height1024cropmodenone
I use an old piece of rubber hose to put onto the end of the new plug as it makes it a bit easier to install by hand into the well. But before I install it, I give it a good thin coating of some anti-seize. You will thank yourself later if you do this, trust me.
DdS4gFpDIOW6Cwidth1024height1024cropmodenone
Q4curzg gwmJdwidth1024height1024cropmodenone
Factory service manual says torque to 133 in-lbs, not much, I know.
Gh9sTSzmbspJFwidth1024height1024cropmodenone
If you convert the in-lbs to ft-lbs you get 11.1. Comparing to the recommendation provided by Brisk, it falls right in line (the plugs are conical seat, 14mm thread diameter going into an aluminum head).
OcPiU4vnGA4cOwidth1024height1024cropmodenone
After installing the plug, make sure to use a small amount of dielectric grease (I like to use Dow Corning #4) inside the coil boot to help keep moisture out as well as ensuring it doesn't adhere to the plug and become a nightmare to remove for the next plug change. In the photo showing how much is coming out of the tube is the amount I usually use.
WmVjVj 7wfWw4width1024height1024cropmodenone
VCX bXlacnkkAwidth1024height1024cropmodenone
LQL43XpGHtxaLwidth1024height1024cropmodenone
After that, installation is the opposite of removal.
Some tips to be mindful of:
1) If you have the composite valve covers like I do, be very careful when torquing the coil retaining bolt. The threaded hole is just a metal insert that can spin on you if over-torqued. If you spin it too badly, that's it...I don't really know of a fix other than getting a whole new valve cover, maybe some sort of epoxy. The book says 62 in-lbs, then another 50 degrees, but TBH, I did that spec on one of my retaining bolts the last time I changed the plugs and it began to spin (yes, I checked to make sure I was in-lbs and not ft-lbs). So before I let it get too bad, I just left it. Luckily it was in pretty tight and didn't have any issues the entire time I had those 542s in. This time around I was just very careful to do it by hand and get them as tight as I felt comfortable. That seemed to work pretty well as they are all solidly in there.
2) If you have an XDI HPFP, you're going to have to remove the low and high side fuel lines as well as the top 2 bolts to spin it a bit to access the coil on cylinder 4. I think I heard XDI had a redesign, but can't confirm that.
ImXbQUY 9b4eiwidth1024height1024cropmodenone
High on Ethanol
Just Ain't Care
USA
So those plugs don't look like iridium. Maybe they are though. Interesting to see something different.
Any idea what your current timing is set at?
Ecoboost_xsport
Sacramento, CA
They are not iridium, the center electrode is silver, a better conductor of electricity and heat. Iridium is used simply to increase life of a spark plug. That's why plug changes could go 100k miles, etc. I will be having to change these a bit more frequently. Here's some product info. Admittedly, it's from them, so take that with a grain of salt.
www.briskusa.com/silver_spark_plugs_brisk_silver_racing_spark_plugs
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
For the noobs in here, no you DO NOT have to remove your intake manifold to change the plugs, though it does make the job a little easier. :p
Great write up. Keep us updated on tuning progress. I am running the NGK Rutheniums currently and for the price difference and the PITA to gap them, I'm not in a hurry to switch over but given the limited stock of the 542 and now M-12405-35T I'm always looking at new options to change over to.
Ecoboost_xsport
Sacramento, CA
Very true on the intake manifold....I just have some other work happening simultaneously, LOL...
Ecoboost_xsport
Sacramento, CA
Copper is still the best I think for performance. But I still have oem ford spark plugs in the sho.
Yeah, back in my Evo8 days, I would run nothing but NGK copper plugs. I been hearing good things about this silver stuff, so figured its worth a shot.
yaycandy
Aerospace Engineer
Hanover, PA
Before the whole lms and fuel pressure issues. When I was having those issues I switched my old sho engine to copper plugs and those lms issues went away. But I still destroyed the engine with e85 and then lms was found to have screwy fuel pressure issues on that same tune version.
StealBlueSho
NA
Fantastic write up!!!! And 100% yes on the dielectric grease, every time, it won’t hurt nothing. The anti seize is a holy war I’m not getting into.. I’ll leave it that yes, I agree with you.
Note on the fuel pump...
It is MUCH easier to just remove the -6an male low side connector on the pump vs removing both lines, bolts , and spinning.
So remove the low side fuel line, use a 17mm iirc wrench, and unscrew the adapter from the pump. Take no time at all and will let you get the number 4 plug/coil out.
916237c6d100da86537b8c50c76550f1
Ecoboost_xsport
Sacramento, CA
Ah....very nice catch. I will try that next time! I wasn't sure if there was some sort of spring or ball valve or something behind it that could fall out and be a nightmare to assemble again. But good call...
StealBlueSho
NA
There is a rubber o-ring on the back. Other than that, you are good to go!
Very curious how the plugs are gonna do, please keep us informed!
ato137528
Mississippi
It's my first plug change on my recently acquired 2013. Owner's manual says plugs are SP-528 gapped .033 - .037. I'm sure that's an old part number. Researching the site here, I don't see any mention of a 528. Can the deep knowledge pool here please recommend the appropriate replacement? Only mod is a cold air intake.
Majestic
MOTORCRAFT SP534 or SP580.
Zpak
Es Aich Oh!
The region, Indiana
SP542’s, which were superseded by M-12405-35T, are a heat range cooler for tuned cars. Also, gapped tighter to help prevent LSPI.
313tiger
