Non PP VS PP BRAKE PADS
bpd1151
Lurking Around
SHOcago 'Burbs
From what I recall, it's not the differentiation between the packages themselves (PP vs. Non-PP) but more so the differences between the GEN4 offerings, versus the GEN5.
High on Ethanol
Just Ain't Care
USA
This is the answer. After the 13+ changes seem to bundle almost every PP difference except the extra cooling, lower gear ratio, and alcatraz steering wheel.... unfortunately for the PP Ford didn't do them any favors...they didn't gain any of the nonPP comforts...and kept the price point.
My 2015 had larger rotors(vented) from the factory as well as struts/springs with tags that indicated PP. Im not sure if this was common toward the end of each MY or if Ford didn't care what parts got installed or how it worked. Maybe someone can clarify this.
TL;DR all PP parts will swap to nonPP, and the opposite.
yaycandy
Aerospace Engineer
Hanover, PA
That steering wheel reminds me of a crazy drunken night which I will share if this post gets 7 likes.
Alcantara steering wheels are good palm scratchers. Only if it had a quick connect option so I could scratch some other spots with it.
I guess I was lucky. The previous owner kept my alcantara steering wheel clean. She was 65 however.
yaycandy
Aerospace Engineer
Hanover, PA
I paid 800$ for a heated alcantara steering wheel on ebay. Locally in york pa. Still some on ebay. I wanted to keep the heated option also. Expensive but maybe stock up on them. One day they will be all nasty and rotted on cars.
High on Ethanol
Just Ain't Care
USA
I paid 800$ for a heated alcantara steering wheel on ebay. Locally in york pa. Still some on ebay. I wanted to keep the heated option also. Expensive but many stock up on them. One day they will be all nasty and rotted on cars.
Fackin sheet man you got ripped off !
You can get brand new raptor steering wheel for that price!
Id hot glue my underwear to your steering wheel for $100
https://www.levittownfordparts.com/...UJoOa1VXL8soCsvoXfSGlFMNHoOUOP-MaAsUnEALw_wcB
4sfed
St. Louis, MO
Yeah but will I need the brackets and calipers as well? Or just the pads and rotors...
Sent from my Pixel 4 XL using Tapatalk
Eric Morris
So every single one of the 13+ had dual piston vented calipers?
Pretty much every vehicle that is not an econo-crap box made in the last 20 or so years has dual piston front calipers.
I think my 89 Ranger had a single piston in front, but the dozen or so Fords I've owned since then have all had had dual pistons front calipers.
There is no such thing as a "vented caliper" BTW. I assume you are thinking of the vented rotor hat?
High on Ethanol
Just Ain't Care
USA
Vented pistons in the calipers.
SHO_Off420
US
Can the Raptor steering wheel be installed on the SHO without major modification?
Lol that should be interesting, but the center of the raptor wheel is much smaller than ours due to the bottom attachments to the wheel being different
7b7af82a138c1f12cc97996ab42b973bA699781b0970d34d7505f21736cd4aea
