PTU Poll
Have you personally drilled/tapped/plugged your PTU?
  • Too skeered
    Votes: 0 0.0%
  • Total voters
    14
Kevin81
USA
Thanks guys....while the vacuum tool works, it's one more thing I have to clean, etc when I use it.
Maybe I'll just do the drill n' tap. I think I saw instructions for the this on these pages...
Forum member Iconic has a vid that's pretty darn good.
High on Ethanol
Just Ain't Care
USA
need a "my whole field of facks to give blew away so I never changed it and didn't plan to replace it." Vote option
yaycandy
Aerospace Engineer
Hanover, PA
Aint all that hard. Drill a hole, tap it and put a plug. Ive done it on harder to get to areas
Frostbrosracing
Austin, TX
If that's the case then why not just put in a "yes" vote instead of complicating things with your special request for a catered response to the poll? That's ok, next time I run a poll I'll be sure to include bibs.Screenshot 20200719 220134 Chrome
bpd1151
Lurking Around
SHOcago 'Burbs
Point of order, as well as for viewer's edification.....
Polls are NOT VIEWABLE via Tapatalk.
Least not yet.
That could be part of the problem as far as participation and/or vote tallys/results.
Least not yet.
Another reason why tapatalk is junk.
yaycandy
Aerospace Engineer
Hanover, PA
If that's the case then why not just put in a "yes" vote instead of complicating things with your special request for a catered response to the poll? That's ok, next time I run a poll I'll be sure to include bibs.View attachment 14752
Your poll asks if we done it. No I haven't. Id rather do it by the side plug. But its not hard to drill and tap it. No need for me to have a drain plug, literally takes not even a half hour to do a fluid change by the side plug.
bpd1151
Lurking Around
SHOcago 'Burbs
Well, I think it's improved vastly since its original release.
And continues to improve with new and regular updates.
A viable option for those on mobile devices. Certainly better than nothing.
yaycandy
Aerospace Engineer
Hanover, PA
Well good sir, my apologies. I mistakenly assumed that you would want to get ALL the fluid out.
No need to really. Get as much as you can out and keep up with the service. Like a tranny, you never really get it all out. Just most of it. I don't wanna try that hard anyway. Most of the fluid being new is good enough for me.
The first time I did do it twice in a short amount of time to kinda flush it. Now I just keep up with it every 10k miles. Just what I do.
10k miles is around a year for me also
Ecoboost_xsport
Sacramento, CA
Yeah, I just leave that side plug in there, it's so much easier with the plug at the bottom. Not only do you get every ounce out, it also makes less of a mess. But to each their own...it ain't the only way to skin the cat.
Ecoboost_xsport
Sacramento, CA
I really like the IDEA of tapatalk and I use it on my phone, just wish it was a little better. I like having all the forums I frequent in one place with out having to open a browser and logging in all the time.
yaycandy
Aerospace Engineer
Hanover, PA
If it was a PITA to get to the side plug i would have a bottom drain plug put in no doubt. First time on the side is hard but once you got all your tools and the know how from your first time. Its actually pretty easy. Getting that side plug off the first time wasn't easy also.
I have always used my browser. Your Note 8 should work great with browser.
