Yeah just roll er up in dough and look for the wet spotIs there a set of gen 3 GH turbos, a tune and XDI in one of the folds?
If so, well ****, I’m game.
Yes, it's clearly amateur hour on my part...turbine side...My turbos both had these cracks on them after 10k miles. You mean turbine housing not compressor right? More heat you put through them the worse they are going to be. I bought cores off another guy with over 150k on them and only was one cracked. Probably because mine almost lived at 100% wgdc. Luckily I warrantied mine and subsequently sold them as new with no warranty lol.
You're lucky I didn't blast you about irrelevant information...Yes, it's clearly amateur hour on my part...turbine side...
You're lucky I didn't blast you about irrelevant information...![]()
https://www.thedrive.com/news/34708...ng-mach-e-prototype-spotted-drifting-like-mad
Sweet 11lb 6oz dear to led zeppelin baby jesus
It just makes me think of a giant RC car lolOh shoot. Ford is coming for ya Tesla!
Alright, I'm back to being paid. Who wants to act like a clown today?![]()
I’m starting to get ****** off. None of this is helping me with whether I need to run 5w30 or 5w20
I prefer to spray an entire can of PB Blaster into my engine...WD40...duh.
No...best method is to remove the heads and empty the can right into the cylinder. I typically use a can per cylinder.Am I going through the yellow dipstick? Just to get all the way down to the bottom?
Hey, no prob..This makes so much more sense!! The can is pretty much the same size as the cylinder, therefore, one can per. Thanks a million.
Oh, forgot to mention...if you just place a can (upwards of course) directly into each cylinder as the pistons go up and down, the spray nozzle will tap the valves and lightly spritz the cylinder walls on each stroke...This makes so much more sense!! The can is pretty much the same size as the cylinder, therefore, one can per. Thanks a million.
