ATP Turbo upgrade help
Ecoboost_xsport
Sacramento, CA
My turbos both had these cracks on them after 10k miles. You mean turbine housing not compressor right? More heat you put through them the worse they are going to be. I bought cores off another guy with over 150k on them and only was one cracked. Probably because mine almost lived at 100% wgdc. Luckily I warrantied mine and subsequently sold them as new with no warranty lol.
Yes, it's clearly amateur hour on my part...turbine side...
Ecoboost_xsport
Sacramento, CA
This makes so much more sense!! The can is pretty much the same size as the cylinder, therefore, one can per. Thanks a million.
Hey, no prob..
Well...
Ecoboost_xsport
Sacramento, CA
Oh, forgot to mention...if you just place a can (upwards of course) directly into each cylinder as the pistons go up and down, the spray nozzle will tap the valves and lightly spritz the cylinder walls on each stroke...
...best method, by far...
stripSHO
Idiot Savant
Detroit
I use bearing grease in the summer since it’s slower to leak out. Then in the winter I flush it out and just run denatured alcohol so it doesn’t freeze
crystizel
