Those who have the DW300c LPFP installed...
Michigan-SHO
Michigan
Got a picture of the floor? And do you know exactly where the opening is on the tank? Is the gas tank the same as the SHO?
Ecoboost_xsport
Sacramento, CA
Yup, I lifted the carpet and there is about a 1" drain port with a rubber plug i pulled. I used my boroscope to see what's under it and I can see the top of the fuel hanger. So I cut a 2.5" larger exploratory hole. I have some random rubber cap/plug I got from who-knows-where years ago that I can plug it up if it doesn't work out. But after looking at it, i know i can cut a roughly trapezoidal shape out. I have access to commercial shears and presses so I can easily make a plate cover for it when done
Ecoboost_xsport
Sacramento, CA
So here's what I'm looking at, I know this doesn't effect you guys at all, and I'll end up posting this on Explorer boards, but I'll be cutting that shape out and I did some measurements. I'll be able to access the fuel hanger through it and not effect any structural points. The cover I'll make will be thick and will seal, but I'll also press some ridges into it to strengthen it as well.
But this will go a long way toward giving me easy access, especially when I get to my PWM surge tank project I've been working out...
y4m-_IrcwRKGL61ZL-NygfdaUoUVYCxyERA6-OBfrDqbrDW8mtlYDDns2k9kxdGP3fyiJlNNJlMrRUfqYxPpYTqbkhW8IfIFVuaxaBpCmd0KKZeC3QMwtoNI52iuq5LqV5-U9lN-BLoo5KJoCR9e-v0tWU25EvAUpQAcM3ICzqLeSwEM8xA0-BEVYZhiAm6RFpKPOqgvQS0KRabULI0Q6MLwg
y4m9EP-sCxQmGQtgDbWrA4brImy4_KpL8imcoTE0PilloWK79NVlSFu3HWRiXitvAaZcdjMeX9lNrTR0hBVh_UgEdO3Qk-2-yKtNkMu2NI-2eey12h57dQ0wil2RHHQa7CqW7tOMVW1Z77k45_w_jwxm3Z0VIbOzpDJgTLnvvpb5Z7GQa0Zh8wEgCtlNdL2fBafWxBZKB2f_Yrx5dQXBGvhyQ
790e8d86655fd02ed940eff5054e1a67
6d0d0b7a1c67a7cb9434a9a65a9ed704
Ecoboost_xsport
Sacramento, CA
Progress...
Oh, this is gonna be SOOOOOO easy to access when it's all said and done. Flip up seat with the press of a button, fold carpet flap over, remove plate with minimal screws and VIOLA...fuel hanger access...
Still need to make the plate cover, that'll be easy, 10 minute job. Drill holes for nut-serts and make a rubber gasket (easy enough). Then just re-install the seat and "these are not the droids you're looking for"...
Rough cut:
y4mnQ_WYXwm9nMPKrIYMyndJGnA9y2jX5wEU2Imkvmbn1zIdbDdS2kygmBUY24UMomxv6sMNBspUAdbqJkf7xSHnzwSQGcR7OOUUWbrvxdq1PvYIJf3hJ1NriICQk95fCF3Ne1YqDg_bMUD6dZl4CS8PGHKrUCziHw7w4XNglaUIvievY6OG9VGT3pQ5ZlRCE1hyAvjzPZORrXST6F8ecrn1w
Edges sanded and deburred:
y4m0NjDg_wbXwXG9k5diRXdyRrzUsOzwrOFzfssPgR063xmrup8wPCRcSVJDvjDBSeEhfIIyvbeqlWZrz2hPoH8Y7E_Pha4UfheTGsB3E7CmNOC681abficDEOQIKyfU-RMTpMwrhlx7_iQxW4cIwEMK9IuSL6immA-xMKMMnncChNLbJS1Nc_vJV_U4yNs9LsUeDVB4a2ytH8kUX8TLZGRkA
Carpet down and cleaned:
y4mUEOqHSEKMawrDfFM6Kd8hqVUE0_O9AaQNOJSRERX7VsIcufSmqhBeueI1enhKM1VxIe3xsSHmKbl_s-Mx2HuHsx_emFjPE9FOnHpr5sOBcKVSwNFjo9ucnRsw3ey8NGmBGsFczsE5DDxOFhA4f4nBonRg7-UGunLH4LRrzl6nSjthgWTCBc4qdqRcSnIyWFE0CQO_lWXN_Eq-LXg4lHgGA
WeatherTech mat down:
y4mWpXvO_hW9jCVFdNdf3HXRpA1xOIWYEQWE9Crq3rfKzh0gJBxTD_tLkmmbSRH8bZe2-o3NjRpjUuBPgFIQuZm0bpk7eFBQ-QVsimxCvx47j07M8Lv1Z09KEi6n_1hlUQqBt8PwTAQ4Kv7h0svSnnxRXDFZsK6T99ykqLKZHROCuVgjk4o8uXKeYNDL9C6-DixBUIA25W01PeD5tj53ufcCg
6500rpm
I've been doing Toyota fuel pump recalls the better part of this week. I can tell you, the Corolla has under seat access and the only thing holding the access plate to the floorboard is that sticky black rope sealer. The same stuff all the asian manufacturers like to use on the door seals. Easy on and off-no fasteners required.
Ecoboost_xsport
Sacramento, CA
Latest update:
Cut the new plate from 8Ga aluminum plate...pretty thick stuff, won't be putting the indents in as this is way thicker than the sheet metal body.
y4mmMD5Zd0m_45BHgprFOAVjSe5pu368fhsQPT7-Fx9y4MyeNyIHj_WOoDYl05OFeSYm9LLPL7nEr13DGuhQrV_baLAfh_qQPLFjfG6BwsEOo6Q1Q1jp0Fb9olYSDxxbdS9E-j21QJc3GxdA7bJGWgWhYnFdB4nhNiXB5TXifjpAywnp6nOwGENFDfz1XpBt3TmJ8rRa1DM2uxrTlXcsYoYuA
y4mC5e182DaEcGEWuRz6VOgWoybh8z2v1l32NurHLHpo_57KOx5666HbEzmZ4jZa0dXQhtTvrq43bY1fSlHrDAkoW9EqDpvrH2iV_TxexIT0nHqj5hlXqayS40FV737TKhwFMSTMXxxpgcHKtLgQsvworG915h_VW8Q7gBN5uhsFBFHnXlM2N-lxTfQJWI_VpO56sb_nL_-rQtOXZnfcw20UA
Comparison of aluminum plate to template:
y4mWcEA6t7IjO0Fxj5Fn72TkgksvdpInkBAb66XYuxRK_rDs2ewlIC51lv89nukvVx-2-nJ77zcAl8WChdnjwKzA0MgVZkyz6ugrJE_zHy_BBnQJEEySxTZ0KA03l1CQ540lROwMOjGpKlgZ6tKsHd7FK86-PqPew9EHO93_gKWtK0lpDh2G49zAfJQfCp75LWA2mBtMAVk7tVTu3mte1RT2Q
Rough sanded and filed edges:
y4m31IMx8AjJJqZcNwgjGfNHhR3XORnvlJYFhlEAFvNYOnomcBvFAB7O7jXGpu4o56AyfpH2efsWZGXveMd0EmAHoNYewuJ-9oaglGelGcNGZJpDZL0nfwc-nQA4mXvlYk00-eSan9DKiWcuR-sE53YrKALYTUsPyJeF-TbrQhvUZOK_4Mjw08BtCaJMI6hkVPUJD5R-VzfvwhqKSNCrobnBw
Fine sanded and polished edges with finished top/bottom:
y4mImn_et6FIrZya5WI68uRvPrWswWASv5XaLWp_LaRdLMW1bCrUA3ayVFYllbOndmE9XoApPQCtDdZpkZR8qQWqD0RP_H4DaoTFVen1Xasd8Yg53FsjZi5IQAafFfMB930bZEqm8UBuFE_4T3ilvuTcQSK9XkoEWAY57IcXOsEL3l-owefwQ3WudwxOhlJgyCTQO6a-k11T6CnBqOsLi8pGw
Mocked into vehicle:
y4mLhRQCRLo3lkLuNvuGWZDgCO0HldYV_heBYTu43KRG8-JiTu_XfCLOAiTx0oDWVSeSx26F8g0jQrxte6BKe9Wvx6HXtYExzErAHXJtAZ0Dt8yTgAJbgmuWeMNNQrmFnKk7pvIL-GEvNKpnDsz8b7N_fEz5YI8otCOjtaBUeFiBf4LSwpRrOHi1BFv5Kinrr6VyEFBp16uuS8pMPNSQyeGfA
Now just to make the gasket and drill bolt holes and install the nut-serts....
Ecoboost_xsport
Sacramento, CA
UPDATE: All Done!!!
Center punch panel bolt holes:
y4mLAWqoEb_ffv03ArTTzf84xbylt-X0adzFZnRir1HKlgl7lgvEwpi9Z7Q02lU8VpGzuyZQpreCyF6-YtA5s1ykE6Qj8d0zX9xEcplaEjK0Ai0xYHNR8Z4APMrFBoHjSAIEmR9Mx6TXIt7rCwb-qipXR0Tt4rOAjpFFT_K7EbeYrnF9M-sfoE2_kOTiAq-xjso2jN5H44g6rEObEGVo1TOPQ
Pilot holes drilled:
y4m1V4nMgDgZAMdZYwM_Wa1N9KOL3KCD1ePvU_CggVy9b6sv1bg_1e3b2FGXqjdk8tBZ_dyUesXaDNj6SXMS5eSiWci4UlZHDJcHrY5qMt23c_Tr-mMltX65kMEPk1NR5o_KhWTspT_E00i8ceC96hugzMQK_ATGAecZHyfXGLVutgc8WUvmOW9-6Tew3XQMp540__kNpZ1iWtqVu4RIzFPsw
Transferred hole locations to gasket:
y4maU93IDnhthAd0xzWZGLk4D5SWQU4k4Vf46yPoBexbWHVsUI_D2Zwf05UwjXwIl2PPv-DVp0bVKFuUPbBfR0JnOjNB6aX6wAEa5sLzuINCUm0mV_zvh2PUTDxyEGG2-6v7DGjQ1vUg2O1ydbGeqJERaYaNiqkk0Y54GLq4qV2RURY8-ow-QlnQx6wF7MfhQCgBcgnaLGy0xv2HkCXl6WSBA
Holes punched into gasket (yes to the Crocs!):
y4mAvvSq2XDiEr8cyeUDFULeLjCMP0CNl5D91sBx8rCPCcAcG2isqWEIdpij5tQBY3BvIFKl1_xo3H0b4MFJbNvHa0mSBV3aTk29KyUjIMVrhVdCf9Jfgcmxnc1WyLXW0tho1uWqslBOL1ZMt6KGJTOzbOZUsVT-UIlFkI2r1uRGdXdt0bfppJiDmYHclZXNYOFotIPyj3g7eVRczyjLf18Ew
Rivet nutt holes drilled in body:
y4mam6AE3IU4TdhUmX4vPA2mf3xEhbpFrF7eBOtkKdih_SWNfL-V3AyFY9wMay_KLKNemQc5QNRQh8acyIFCs1jfjUrdTxF2DDjtKHa4RZ3-Kqoq_UcQ7kl72nxVjB58LBLGBXVBng-cgjBxZE5YABj4icQhJxTlsTnnQQQPQSL543l7Ump4hXtABBSlH6CmJcKa5fXz6M6L1yD2dmIxVeS_w
Rivet nuts installed:
y4mIfRHKJl0CHO6IGGt6x8XGUDCyo1ye_CUpEEapHbXfYyXaEKI6kKRGmHMO2MMFsdmZAeWcv0tFNEyOMRyS7uogmvO-SjK5jJcadwxIME-ETaOaCQRzIT-gfSpgu0I3YdsFvBgeVIli6OG8Eju2qBbSAg-2m_FKhXDsJzNiQyEoTK73aDV9Bx3K2fl4KZQncFU5MlOIBqFnfj231vOORZkpA
Had some DynaMat laying around..helps a bit with sound deadening
y4mRo7KD6NJDlQFkcs6pIo0YX3Ja9_Xzf_gJCREUgcbpMZr-Q_AIWrFFvquzy9ck6F2drVo3OraSFw74mJOI6kgytpAABiITykW8JFmQr_o3UJ-Q1ESeXxZbkAqaQhtCPomlAuieSzntVP1vE43ASCr3xo_B5fuYKN98R4va6taxK0SIicJux-w0wgJb9IAx_6dHTvv4YIBkjPjWT08KtcO9Q
Panel installed:
y4mG9coxwSsp6GQs_RPU8gZqkUerr5fdM0oW3k5Tf2zgLzx9VUsSLI7GVj_hTE5BVefWWfIDDdpyBkNaVMXS4vHlwTxIGgNdSXiE7vsi6mrwS1vwVUMQzEblX9rbIkSjSRrrKQTO7prAmDQ7Dd2KxnlQQbVJoQj6K0B7NUB1ObokRj0xnn4oKFiXuRtTD3o_eds93uZWS16IQw6aW1ix2xIkA
Hardware used:
y4mHb88zny85E-4zy3472OlwjpErvFuYc6qF4XkFPAiHJ0W4fFb4PXtIUu3r781PzDBGtgFTkgMPCWr4csqYEH0zvuEz9RXkA7fkSIkyBiHEtSEATLAFBUAIyEGHgSvhBq3Z1KJKyPm7j0-HZSvY5awPN_d4-8v20FVPs3bRf6TMDq4MXH9IfearoT_AOJNaMrRjwsCH_N0DWwapq62U0RuDg
Seat installed:
y4mqnZ1W6G9oxvG_lD6jrluU1jwAzf8J3luzxt2Ui_0P7w0vKNd6__wRuIbqlkheKMMuOhiUIHrBkYmoFMjIdbKQsmXlUzI9JHnSMvo-1wjZHCmIAWIUv_-jd4Wf0-q1m7YAwfFnQmFiTXxNxcRwlcSGkUpZ70OjnCqOz4jxe8tyYCzYGKgqgBGFk_elpPVVsoY0ezBHj59tkaCdmIPiJlxxA
Easy access when needed!!:
y4mUS6ppvI2rmcjG53qbcdMbXKphGwQBT-Lf5FWAoSjbG2nPd2qnV9euA5OCVanBJESzgN7zOhRJnQXD-9pHg45N3PCKnhYzxC673BN6fpNoRr3J9k_fYaci-dYzbPK12whpLnR_cqtZGeOR0id5ApHV726S22c7Kp5FihbdQ4CCQSUlk7Avx9oOpMkWZvNpbejhj9EDnWacgRXq7bd8lDQnQ
crystizel
