Ecoboost_xsport
Not quite sure where this post belonged, so I put it in the Performance section....could be in General or Maintenance, though. If it's in the wrong place...moderators, feel free to move it.
Finally getting around to conducting tests on all the different LPFP setups...
OEM, DW300c, Hellcat (Walbro 525) and my custom dual pump setup.
Here are a few teaser pics and some VERY preliminary results with the OEM and dual pump setup. Next up to be tested are the DW300c and Walbro 525. I can't get excited yet for the dual pump results without first seeing what the DW300c (most common LPFP mod) and the Walbro 525 flow. It might be a dud, lol (oh..and a royally expensive one, LOL). Red-bold values in the charts are where the OEM voltage output to the pump sits at during WOT.
I tested various voltages to simulate results for those wishing to use a boost-a-pump. Fluid being used for the test was e85 as that would be the likely candidate fuel for the dual pump setup.
Keep in mind these results are based on flows THROUGH the LPFP module (not the pump by itself), fuel filter, all fittings and bends, and with THIS particular test setup. The important numbers to look at are IMPROVEMENT over OEM, as flow within the vehicle could differ slightly. This test is an apples to apples comparison, trying to minimize variables. I'm unable to test thermal output (how hot they get while running), which would be another valuable data point (though AMP draw could be used to infer some generalizations of thermal output). My thermal imager took a dump on me a while back...
Full YT video in the works.
