Wasn't there a lowering compression post? 2/10 would not recommendYou took the easy route of trying to destroke the 3.5.
Actually I was! No random knock, just making good boost and oops. Fuel trims look good and all. Brad said data looked normal but engine obviously didn't like the torqueWere you datalogging when it went down?
Yep, exceeded something! I'm not too stressed on figuring out exactly what happened because either way it all has to be done no matter what it was.Well you exceeded the cylinder pressure limit...but it would be interesting to know why just the one cylinder.
Also I datalog almost always just in case something happens or seems different. Usually save around a month worth before zipping and archiving. Mainly because I've been doing my own tuning and its a learning curve and without a dyno its difficult to measure the changes.
Rod bearing did not spin! The car has been putting down insane torque (for stock internals of course) for the last couple months. Car had been running perfect until it just was not happy. Purring then clunking just happened in that moment.In the world of OEM repairs I've only seen rods bend like that from being hydro locked. Great that it just bent and didn't break and exit the block. No scratches on the effected cylinder wall is also almost unheard of. For a first time and doing it at home that's exceptional.
Were you running it hard within a few days of the failure? Reason I ask is on a rare occasion I've seen a bent rod with the only symptoms being that it was running rough/unstable or misfire on the effected cylinder due to lower compression from the bent rod. It might take a bit before it finally effects the bearing. Did the rod bearing spin?
Lol you are the firstHas anyone used the term "that ship has sailed" yet?
Wow.
My nail doesn't catch on anything and nothing visible. Looks and feels just like all the others. Waiting on the crank to arrive then to the machine shop most likely tomorrow and they'll give me a full run downYou sure that cylinder is just a hone job?
