To add another facet to this thread, it would be nice if the G3 A pillar clusters were still available. Would be helpful at this stage in the cars life to have needed info on fuel pressure, trans temp. battery voltage, etc. to better diagnose issues that older cars have.
I think Newberg has the ashtray area gauges.
Does anyone remember if fuel pressure is one of the OBDII readings? If so, likely you can get it simply by plugging in a ScanGage. They plug into the OBDII socket and can run up to 4 separate readings continuously. I used to have one going in the SHO to keep an eye on stuff like the intake air temp and the engine load.
pax, smn
pull the engine side hose of the fuel filter off and hook into that and cycle the key / check the pump that way. i think you should have something like 35-45psi of pressure from memory.
It doesn't appear the kit I borrowed from Autozone has a fitting for that hose. It does have some short lengths of hose but no barb/****** to attached to gauge. I'll look again.pull the engine side hose of the fuel filter off and hook into that and cycle the key / check the pump that way. i think you should have something like 35-45psi of pressure from memory.
