boost gauge
Subietech
Florida
Hey @bpd1151, how were you able to display gauges from your mycal device? Just got a mycal touch recently and can’t get dial gauges on it
Lostneye
NY
The guy who made them just pasted away, and had sold the molds to someone else. Not sure if they will be made again.
I thought I saw something recently someone is looking to start selling them again... Mike Bambic maybe?
That is the old mycal they do not sell anymore. The one LMS just released is different.
V1kesfn74
Anyone know where to get the center pod inserts anymore? Also what gauges are those that are labelled SHO. I have seen them before but cant find them anywhere
b4black
IL
Keep it simple....
Easy to see for the driver, doesn't look ricer like A-pillar pods. More gauges than you'll ever need. (I believe the newer version has 4 displays per gauge)
A little pvc pipe, black paint and Velcro. (Trim the pipe to length, then use the miter saw to trim a flat spot on the bottom.) Tuck the cables behind the trim panels.
Gauges
b4black
IL
Boost, or MAP is a generic OBD2 parameter. Any thing that connects to the OBD2 port should display Boost.
Matt M PA
I helped a friend put the AeroForce gauges in a Challenger and have been thinking about putting them in the SHO in the center speaker location
I have an older ScanGauge in the Excursion that has 4 items displayed. For those of you with the AeroForce gauges in your SHO..what do you have those displaying?
