92 sho 5 speed will not accelerat
blk\blk90
TX
Does it rev while sitting still? How does it idle? Any other symptoms?
zoomlater
Seattle, WA
clutch slipping? Does it happen when you step on the gas in 5th and it doesn't accelerate
Rex
Kansas city mo
It runs great other than that does not rev when setting still it did fine on the highway yesterday and i just had a new clutch put in 3 weeks ago
please pull the codes and let us know what they are.
Rex
Kansas city mo
Codes are 136 oxygen sensor not switching system lean left or front 172 oxygen sensor not switching right or rear 411 idle speed system not controlling idle properly
blk\blk90
TX
What's a good way to test the vacuum system? I saw something about a smoke machine somewhere, or is there another way?
I typically will use a can of starting fluid. Spray a little (not a lot!) at a time in short bursts. The engine will speed up when you are spraying near the leak.
Did you loosen the intake runners when you remove the whole intake? Sometimes it doesn't seat and seal correctly if you shortcut it. Happened to me before and now I loosen and tighten them back up after seating the intake every time.
There should be an EVTM vacuum manual page or two posted around here to look for hose connections. The big stuff up top is the intake to head seal, the intake runners leaking, and the hoses off the intake to get a start.
Rex
Kansas city mo
So i changed the idle air control valve and drove it it still drove like shit so i changed one of the o2 sensors went to start the car and now all it does is click wont crank at wont jump start eather the battery is 3 weeks old
Sounds like the starter. But you really need to get a battery reading before you chase it. Since it's a manual transmission car, you try bump starting/clutch popping it from a roll?
zoomlater
Seattle, WA
Check to see if there is 12V at the starter when the key is turned to the on position. This will help to see if the problem exist at the ignition, the wiring, or the starter. If there is power at the starter, use an insulated screw driver to see if the solenoid is functioning by jumping the contacts. I would also double check all your grounds are clean and secure.
