Rex
My 92 sho 5 speed will not accelerat when i step into the gas on the hiway
Yes in does it in 4th and 5thclutch slipping? Does it happen when you step on the gas in 5th and it doesn't accelerate
It runs great other than that does not rev when setting still it did fine on the highway yesterday and i just had a new clutch put in 3 weeks agoDoes it rev while sitting still? How does it idle? Any other symptoms?
Codes are 136 oxygen sensor not switching system lean left or front 172 oxygen sensor not switching right or rear 411 idle speed system not controlling idle properlyplease pull the codes and let us know what they are.
411,172,136 are the codes im gettingplease pull the codes and let us know what they are.
So i changed the idle air control valve and drove it it still drove like shit so i changed one of the o2 sensors went to start the car and now all it does is click wont crank at wont jump start eather the battery is 3 weeks oldCodes are 136 oxygen sensor not switching system lean left or front 172 oxygen sensor not switching right or rear 411 idle speed system not controlling idle properly
Yeah i have power all the dash lights come on radio everythingDid you check voltage at the battery? do you have power other than no start? could be starter
