Glove Box Re-Assembly?
laurin1
Flower Mound, TX
I changed my cabin filter and now I have a part I can’t put back together. I see how it attaches, but physics won’t allow me to do so. To connect it, I have to close the glove box so far, my hand won’t fit in there.
Help!
Also, what does it do?
089bff721c6a9732e742e514c0059689
A8abb02450cad47e62c77e6706245cad
Sent from my iPhone using Tapatalk Pro
SaveMelMac
Texas
Undo the plunger in the first pic. Should be on a hook. Then reassemble the piece in the second pic.
laurin1
Flower Mound, TX
Tried that. I can get it connected, but then I have the same problem - I can’t get my hand behind the glove box to put it back on the hinge.
xFallenxCripplex
You put the plunger all back together then put the glove box on the hinge if not done so already then let it lay on the ledge of the door as you close the door the plunger will get close to where you need to rehook it to the door and should get it from there
xFallenxCripplex
You need to unhook the inside plunger from the door it slides one way then pull it off then you can reassemble it.
E1687ca3b9b164fa52988b589decf618
laurin1
Flower Mound, TX
That’s what I was looking for! I thought maybe the bottom piece came off, but couldn’t figure it out.
Funny, I watched that same video to know how yo change the filter.
