mrhighcaliber
Wow what all was done
Timing chain, guides/ components, water pump, billett oil pump gears, new timing cover (motor mount punched hole in accident), Painted timing and valve covers, new front turbo oil feed line and quick connect fitting from head. Repaired broken HPFP connector. New Msd coils, all new turbo and valve cover gaskets, oil pickup seal. ReInstalled my upgraded turbos, replace front cover of rear turbo from donner (outlet port snapped off in accident)8a23babcc3d0477d55795f0e3a6a330a
C374b153f34c6baa81260340c1e7b5d6E635c8e9ae7ed7865c0ac4c27456d12eAf63814f0fe10e2f5431779a2aa685cb
sanman
Damn you've been busy looks like spaghetti to me Great job.....
StealBlueSho
NA
EPP Hot Pipes installed.... Firestorm HPFP sold off... new XDI pump incoming tomorrow or Friday... off for GH turbos and EPP catted downpipe install on Saturday... pickup and dyno on Wednesday...
EPP Hotpipes install was OK at best... requires A LOT of adjustments to get them straight... this I believe is due to the this tab not being welded on in the correct place.. there is enough slop in the couplers to adjust them.. but still...
93211e27c8962111bd67c8338e24b8a0
2b0bfe1dbabf71c6f0c87a01a2875512
jman1200
Ontario
Weather finally cooperated, removed the Winter tires, lubed the rear caliper pins and replaced the front ones as the boots were torn. Painted the rotors to get rid of that ugly rust appeal, painted the calipers, drained the transmission and replaced 5 liters of fluid, pushed the exhaust back in place as my daughter had "re-positioned" it after going over a curb.
32725778037 bf1ef984a3 o
Jeff2017
Got new BF Goodrich G-Force Comp-2 A/S tires put on today. Two of my Michelin MXM4 Primacy tires were down to 4/32nd and 5/32nd. The rear ones. The fronts were at 7/32nd but I hate mixing tires so they gave me a credit for the front two which they can sell as used. Car only has 16600 miles on it so I was a little surprised that the Michelins were that worn down.
CCXVI
I run those on the front, as the summer sport comp's didn't last 6K miles. These seem to be lasting a lot better, but tomorrow I'm test fitting a BFG K/O2 so they may be off soon.
NdWcavB
Also got my EPP gauge pod today, boost gauge won't be here until friday because I had to get the fancy one of course. I'm working 12 hour nights fri sat sun so no idea when I'll get in installed. Thanks again to @bdp1151 for showing me how easy it is to plumb the tranny temp sender
markmoomnu
