Where do I tap in for oil pressure?
CCXVI
I ordered the triple gauge pod, and other than boost I'm thinking oil pressure and maybe temp or trans temp, but I'm not sure where to tap in for any of them.
bpd1151
Lurking Around
SHOcago 'Burbs
If you have a PP equipped SHO, you can tap into the aux oil cooler, as there's an unused bolt on the housing, that can be removed from the housing, drilled/tapped and the sensor then installed into that opening.
Least for oil temp that is.
****edited to add pics8ad77d8392b158ce811ef1e70c313acdFd4029734fbf195f96da68d88d3561ceC136e6d845d77c6e253282ca1e7cf7b1Fd7d3cf9a8a57b01387d35e9f94602b6
bpd1151
Lurking Around
SHOcago 'Burbs
Sensor for trans temp, can be placed into the smaller of the two bolts at the bottom of the trans pan.
It's the one used by tech's to check pressures.
LMK look for pics and I'll edit/add them to each of my replies. Gimme a few.
****edited to add pic27127aa2fd5f066a2f0d1cf73eb91276
CCXVI
I don't have a PP, but damn that's helpful on the trans temp! Definitely going that route then.
bpd1151
Lurking Around
SHOcago 'Burbs
I don't have a PP either, however the aux oil cooler can be ordered and VERY EASILY retrofitted.
Seriously it's so stupidly easy.
15 to 30min tops to do it.
CCXVI
That's tempting then. How much does it cost? I may go voltmeter since I've been having electrical issues lately too.
bpd1151
Lurking Around
SHOcago 'Burbs
Like $100 for the aux cooler itself but you'll also need #11 in this diagram as well.
It's a matter of two or three bolts from what I recall.
Remove the old, original piece, then install the bypass part (#11 in diagram) then place the aux cooler onto that bypass part, re-install the 2 or 3 bolts, wallah. Done.
https://www.tascaparts.com/oem-part...hdXJ1cyZ5PTIwMTgmdD1zaG8mZT0zLTVsLXY2LWdhcw==
chrisjobe
Williamsburg, VA
https://www.tascaparts.com/oem-parts/ford-oil-cooler-8a8z6a642a/?c=Zz1jb29saW5nLXN5c3RlbSZzPW9pbC1jb29sZXImaT1NUzE1MjYwNSZyPTE0JmE9Zm9yZCZvPXRhdXJ1cyZ5PTIwMTgmdD1zaG8mZT0zLTVsLXY2LWdhcw==
So the part from Tasca has everything you need?
bpd1151
Lurking Around
SHOcago 'Burbs
I have old part #'s, from way back in like 2011/12. I know they're no longer applicable.
However, besides the part # I linked, which is for the actual cooler itself, if you look on the diagram the other part needed is #11.
Maybe SHOdded can help find that for 'ya?
Here's my "How-To" tutorial I authored many years ago on this subject matter.
Still works to this very day, on those Non-PP equipped owners like myself, that want (some) of the benefits of a PP equipped SHO.
Again, most part #'s are obsolete as FMC changes their inventorying system annually.
But it should help steer ppl in the right direction.
https://r.tapatalk.com/shareLink?ur....0&share_tid=523&share_fid=56487&share_type=t
CCXVI
That's really neat, thanks! I'm already $500 in on this gauge setup so I'm gonna wait on adding anything else lol.
dinojc86
New York
Thanks for the info...........I have a trans gauge that I'd like to install and this inof is helpful.
Sorry but did you say this was a PP?
bpd1151
Lurking Around
SHOcago 'Burbs
My 2010 is a *NOT* a PP equipped SHO.
However, I did pioneer retro fitting many of the options that a PP equipped one has.
Not all, but most. Glad the info was helpful. Makes feel good that it's still of relevance, even years later.
bpd1151
Lurking Around
SHOcago 'Burbs
Actually I have a trans temp gauge, this is for pressure?
No, mine is for temp.
But I would think pressure can be found in a PID somewhere. You'd have to ask those owner's who are much more "techy" than I on where to go to find that info.
crystizel
