Brakes, Brakes, Brakes...
Lostneye
NY
Boy, I come out here once every 3-6 months, and get a bit behind!
Anyway, I assume that everyone here who needed pads & rotors already bought them by now!
I went just through my Unread since last time, but not through the earlier stuff.
Anyway, some thoughts.
Carbotech = Wonderful! Yes, dusty, but "nice" (non-corrosive) dust, and they WORK!
EBC: Yes on the Yellow. They were supposed to be better than the Reds (which have been around forever), with a bit less dust. Orange sound good, and they have a Blue, that's more track oriented ( if I bought EBC, I would buy Blue).
Reds are an old design pad, better pads out there with the same noise & dust.
Hawk: HPS are fine for pure street, but the new HPS 5.0 would be better. Really, the HP+ are great pads, and the new Street/Track also look good.
They have a Ceramic, but the Hawks, as virtually all other "Ceramic" pads, have a sprinkle of ceramic, and their main claim to fame is less dust, not
performance.
Here is a chart of the usual Hawk pads: http://www.hawkperformance.com/street-performance-compound-application
Again, on rotors. Nobody is doing 500-mile NASCAR or IMSA racing at 150+ mph for hours. BUY THE CHEAPEST BLANK ROTORS THAT YOU CAN FIND!
Only exceptions are if you really must impress your Cars and Coffee buddies with the slot/grooves/holes/whatever.
Spend the $$$ that you save on rotors (and brake fluid, Valvoline Synthetic DOT4 is just fine) and spend it on brake pads!
While I agree with getting blank rotors for a street car but I do not regarding the cheapest you can find, especially for the 2010-12s. These are heavy cars with the 10-12s have marginal brakes we need all the high quality steel we can get.
marius883
Orlando, FL
Agreed, if you go buy the OEM rotors, they will warp on you as soon as you step in them from higher speeds lol
SHOinVa
Tidewater Va
You know it is a scientific fact that drilled an slotted rotors disturb the air flow across the rotor in such a way that not only does it allow for shorter stopping distance but improves the over all performance of the car to include gas mileage. There you go you have now read it on the internet so it must be true.
C.
RonPorter
SHO Club of America
Lake Orion, MI
Nope.
These cars aren't unique, and rotors are not the issue. Folks tried to use that same argument with the original 10.2" brakes on the original SHOs. Rotors don't warp, brake pads overheat/melt and leave irregular deposits on the rotors.
With better pads, braking improves, and nothing that rotors can do unless you have better pads.
A few years ago, I had a stock white 89 SHO, with all stock rotor sizes. With Carbotech XP pads, on my usual cheap rotors, I ran VIR and BIR with zero brake issues of any kind. SHO track guys learned many years ago what mattered.
RonPorter
SHO Club of America
Lake Orion, MI
Again nope.
They aren't warped, if they weren't grooved, you could have them cleaned up. But, if you put on the same pads, the issue will happen again. Truly warped rotors virtually never happen on street or race cars.
Rayme20
I just replaced my pads back in August 2008, with the Ebc yellow stuff pads, while I hate the dust, I love the stopping power. It seems I have already went through the front set of yellow stuff( wow only 7 months?) So I am looking for a suggestion for pads that have the stopping power of yellow stuff, that may last longer than 7 months:)(and if possible less dust). I have scrolled through the post but there is like 90 pages on this post now and no real specifics on what you all would replace yellow stuff with, suggestions?
bpd1151
Lurking Around
SHOcago 'Burbs
Many have transitioned to the EBC Orange's, which came out well AFTER their Yellow's and have reported good or better results with them.
Give them a whirl.
I believe they are categorized as a 'SUV' type of pad offering.
Rayme20
I looked for those and I couldn't find them listed to fit a SHO and I want to make sure they fit, any item numbers or links I can get from someone who has them already?
Sgtmeatsauce1
2013 SHO +pp
New Jersey
For the price and longevity the stock PP 13 pads are superb. I had reds(burned up) the yellow(lasted 14,000 miles and ate up my expensive rotors. Went back to above grade OEM NO holes or slots and PP pads. Honestly in hard DD I can hardly tell the difference. Stop on a dime, repeatively and 1/4 the price. Minimal brake dust too!
Rayme20
Will they fit on a 2016 non pp sho, if so where do I get them?
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Rock Auto ....2016 pp Motorcraft pads will fit.
Have EBC OEM type rotors no holes or slots.
I check my old box see what I got....
klrsmith
Central FL
FWIW, I went with Power Stop Z37 Top Cop pads and Stop Tech cryo slotted rotors while I had things torn down to replace all 4 wheel hubs last year. I'd say my style of driving is "aggressive" and this upgrade over stock has been well worth the time and 3 stitches I had to get on my right thumb (freaking dust shields...) :biggrin:
Stoptech Cryostop Rear Left- (126.65137CSL)
Stoptech Cryostop Rear Right- (126.65137CSR)
Stoptech Cryostop Front Right- (126.65136CSR)
Stoptech Cryostop Front Left- (126.65136CSL)
POWER STOP Z371612 (Z37-1612) x2
POWER STOP Z371611 (Z37-1611) x2
TIMKEN HA590478 x2
TIMKEN HA590261 x2
RonPorter
SHO Club of America
Lake Orion, MI
Give them a whirl.
I had to look up EBC brakes again, as I can never keep the colors straight after the Yellowstuff!
https://ebcbrakes.com/products/brake-pads/
It appears that the Blue pads are the next step up after Yellow, and if you read the link for the Blue, they are described as such. Orange appear to be the next step above the Blue.
As was stated in these descriptions, there are elevated noise and dust levels. That's just the trade-off for good braking. It's possible that the dust from these is not as dark as the dust from my beloved Carbotechs, and hopefully is as non-corrosive as the Carbotech dust. The only really corrosive dust I've found is from Hawk Blues.
merp
Flower Mound
I have a bit of experience with the Yellows and Blues on a no-longer-mine 2003 Cobra. The Yellows have a great initial bite and work at all temps including below freezing, and only fade a little once they're hot, but stay grippy enough for track use. Blues, OTOH, have _zero_ bite until they're hot, and fade less than the Yellows, but if you've been cruising for a while and the brakes cool off? Your next stop will have 1/4 to 1/2 second where the pads do about zilch, followed by a HUGE grab and they haul the car down with surprising force. I don't recommend them for daily/street use, unless EBC's changed the formulation.
I've not used the Oranges, so I can't speak to how well they grab when cold, but it sounds like they have the initial bite of the Yellow, but with the better high-temp performance of the Blue. When I need brakes, I'll probably give them a whirl.
