BamSHO
That is for when you have a massive coolant leak, like a hose blowing. It goes into limp mode so you can get to someplace safely. It has nothing to do with fuel mileage at all.
Im not sure, i didnt read into much after that article but our cars do have the cylinder deactivation to warn us to stop and all if it ever would be too much of pulling. Say out west where mountains are real
Alternating cylinder mode in the event of an impending catastrophic event, is much different then "cylinder deactivation" as you've clearly articulated above.
You NOW CLAIM that people shouldn't tow with the SHO, but yet your entire premise in this thread has been to quite the contrary where you spew at the mouth about how you've done it, and how it's ok to do. Tapatalk
Yeah well it's good to get first 80-90 percent on Dyno then you data log to get the rest.The 1.5l ecoboost has had it for awhile, again you guys dont know the platforms. Thats why you go to livernois and have them tune your car on a dyno....for the strip??????. Werid because tuning on a dyno and running on a strip will make you slower
No harm to try and tow as long as you know what you are looking for for early signs of it not working I will also have suspension bars or whatever you call them that article claim will let you tow more then your car weighs and my RV weighs a little less so i will still be taking it slowly. But it was nice to see an article that showed it's possible and runs well.
Yes I have I have also weighed the car to know it's real weight it's ok if you take things slow. Work your way upYou better look at the tag on the door for GVW and CGVW. Most passenger cars are overload with people and luggage. Then you add a trailer and it's contents. Seriously people dont realize this till it's too late. Trucks and large SUVs are designed for this, not our cars or and cars. Just not worth it.
Yeah you will probably get there before me my wife has been fighting me the whole time from what others have told us when I asked some people I thought would know but they too are novice towers.You will have to let me know how well it runs pulling. I probably wont pull with mine till early summer at least
Trailer does have brakes on it and I'm waiting for the RV guys to get back to me if they custom made there hitch or used an off the shelf class III for the TaurusAnother couple things to think about. Weight of your trailer, if it is over 3000lbs, it requires trailer brakes, and what class receiver hitch to you plan on using?
The sho should be real good with pulling. I had a friend with a turbo supra. And it pulled real well, couldnt beleive it. Just gotta have an open mind, ford says not to pull with it because its a performance sedan. Turbocharged cars are best to pull with and can outpull some trucks. Im willing to bet our Sho’s can pull just as good as the f150 when put side to side
I will be data logging looking at all tempsSHO will not stand up to long term towing, esp up alot of hills. Make sure you have an big aftermarket trans cooler installed, cause you are going to make that little trans hot. Best of luck to you
Yeah although from North Pole to Delta is not very hilly which is where I'm going to be doing my first test at least to eielson all two lane 60mph highway 20 miles then to Delta is about 40 milesYou should be alright, cant wait to hear how well it pulls with hills and all.
I always manually down shift with the peddles down hill. And I will be adjusting speed to whatever temps I have so I know how hard I can push it.Maybe one of the guys that tunes these things can get you a pulling tune. Just to keep the revs low and stay in a lower gear even when coming down the hill. Or you could just manualy do it with the paddles
But first I have to see if the suspension actually can handle it.
I would like to put a 2 inch receiver hitch on my sho but they say that the 1.5 fits the sho submodel other taurus models can take the 2 inch. I am not planning on towing but have a bike rack that connects too a 2 inch and would like to use it without adapters. Thoughts?I have not ever towed with my sho and never said i did. I put up the thread with an article of someone towing with their sho. Another member on here does and got good help from that article and talking with the person who wrote the original article. I would like to tow sprint cars with my sho in the future and today got a tow kit and wiring kit that is plug and play on the sho at an auxilary port hidden in the rear
