SBS, how is it misleading? You said it yourself. The GH "blown motor" was due to lack of oil.
I haven't heard of LMS motor blowing up either. Did the guy on FB say exactly was the cause? I take alot I used to see on FB with a grain of salt.
Your 2010 didn't blow up correct? It was hurt and you traded it in correct? However IIRC, that was after numerous tuners, tunes, and meth right? I would assume track passes? IIRC your car was running mid 12's? What caused the injector to hang? Usually a mechanical issue when I have seen them hang.
I think the statement talking about your experience with AJPTurbo is bias. You knowingly and willing used your SHO as a test bed. When you work closely with a tuner and ask the tuner to turn it up, and keep turning it up, you inherit that associated risk.
I get the dorked tunes ect, I come from the Turbo LS HP Tuners world. However, we all know about the inherit risks pushing a set up. I melted 3 pistons in a fully forged 376, because I told the tuner to shoot for 1K hp because I was right on the verge of being out of fuel at that level. I was chasing the 1000 hp club. Cost me a 8K short block (callies crank, rods, JE pistons) and I learned. However, I did not blame the tuner. I blamed myself for not listening to him, and not further upgraded my fuel system.
Ok, I am going to address this once, and then I am done with this thread.
EVERY tuner has had a motor compromised for one reason or the other. Whether it be from the tune or the end user.
The gentleman on Facebook and I pm'ed several times. It was a brand new SHO, he loaded the tune, and threw a rod shortly after. Could it have been a faulty motor from the factory? Sure, could it have been the tune? Possibly. I was simply pointing out that LMS tuned cars have failed.
This history with AJPTurbo and I is pretty well documented on EBPF. I did run the gamut of tuners with the 2010 SHO, again, well documented on EBPF. Brad did a lot of "Lets see if this works" with my 2010.. I was the first tuned by Brad for Meth, the first besides his own with the boost regulator mod, and there were a lot of kinks he was working out in his own tuning methods that many are reaping the benefits of at this point. There were tunes he sent that had nothing to do with adding power but controlling power production that resulted in A LOT of "WTF happened" moments. The one where he removed ALL torque management, ended up commanding over 20psi of boost, and a slew of other "oops" in the same tune resulted in the bottom end knocking. I still have the logs. And to be quite frank SM105K you were and are still not privy to the conversations Brad and I had while we were working out the kinks. There is A LOT of information and data that I didn't post and don't feel it needs to be posted. Brad is a great guy, I still recommend him as a tuner, and still highly respect him.
What ultimately caused the injector to hang? I never had it diagnosed. I was offered a lot of money for the car on trade in. The list of codes generated were quite long but unfortunately I did not document them all as I was offloading the car. But to your point, that car was driven hard, but was always extremely well maintained.
I understand the inherit risks with tuning very well, and the risk you take asking a tuner to turn it up more. I never once asked Brad to turn it up more than he was willing, as a matter of fact, I asked him to turn it down over his objections. Also a fact is he commented on my LMS tune load stating it was pushing more than he was and to be careful as he knew I didn't want to push it that hard.
There are reasons why after that tune caused a mechanical issue, I didn't run around the forums "Brad compromised my motor!!!". And I still don't run around saying that all over the internet. What I did imply was that its foolish to make claims that a tuner has never had a compromised or nuked a motor running their tune. Every tuner has a story about a motor that went belly up under their tune, doesn't mean its the tuners fault.
This back and forth about LMS is getting stale. Is there a problem with the V11 tune? I think for a large majority of the SHO's it appears that there is. Is LMS aware? At this point, I am sure everyone at LMS is aware. Are they working on fixes? With out a doubt. Given their track record of solid EB SHO tuning since 2009 and this is the first tune that has received this much back lash, I would say that you can't be perfect all the time. Is it a reason to drag them through the mud? I think not. So far no one on this forum has posted that their SHO blew up on the V11 tune, running poorly sure, but no catastrophic failures. I have no doubt they are working on a solution and has been proven that they are sending out revisions for it.
