https://shoforum.com/index.php?thre...o-your-sho-today.130526/page-107#post-1499353
Added the brake upgrade post here as well.
"Not even mad" LOL. A multitude of possibilities - from sensors to TC to clutch. Fingers crossed.
Sounds like the direct clutch took a dump.
Edit: after further thought, If fist gear drive is affected, low/reverse is more likely. But direct is a common failure point.
Cool, if you have 1 and 2, and no 3rd, then it is a direct clutch failure.
The d.t.c.s you have are mechanical. So a shift soelnoid, valve in the main control valve body, or a clutch fault internal to the transmission. You can remove the main control and inspect the valves/replace the solenoid body (can't do individual soelnoids), or replace the whole thing (soelnoids and valve body). If you replace the whole part or the solenoids the P.C.M. will need to be updated with the new solenoid I.D.
The 1k price sounds like they were quoting you the r&r of the solenoid body and re-eval. Not a transmission removal and inspection, but 7 hours makes is sound like it was. Hmmm.
As you noted, you can't test SSB mechanically so it's only ruled out through replacement.
Luckily, your photo efforts did not fall on deaf ears. I'm taking your photos to the plant when my back heals enough to go back to work. After a personal check on the assembly line, I will go to the appropriate Quality teams to see if this can be addressed. Understand that our motors have been through many revisions since 2013, and if anyone else had this hose come off under warranty, it would have been addressed as the site manager would have asked "how can we be sure this will never happen again?' Best revision? Fine threads on the main bearings in late 2015,Been DD'ing the SHO for the past 3 weeks. GTI is getting worked on. I took the SHO to Cali a couple of times, ect. During the second trip, I started getting over active BOV's. Mine are vented to atmosphere, (maybe re-vent them back to the stock locations, I am the fence) so they are very noticeable. Very light throttle they are doing their song and dance. I chatted with Brad and he told me log it. Took me way too long to get the logs to him (my fault).
Friday night I took the BOV's off to check the o rings and they were good. I had the cover off and everything and did a once over of the top end. I went out and data logged the car and sent them to Brad late Friday night. I looked that the logs and noticed there was a difference in tip boost and MAP boost pressures. I was seeing 29 psi at the turbos, but only the commanded 18 psi at the MAP sensor. I didn't think much of it at the time, being up for 20 hours didn't help this. In hind sight, I know better.
I ended up going to the track Saturday afternoon/night and ended up running a PB. The car was getting it in the 8th mile, but just didn't seem right on the big end. It has run as fast as 112 in 1/4. It only ran 108.98 as the fasted pass that night. Packed it up disappointed because I thought she would run faster with it being way colder, way better DA, and a way better 60 foot. I know the 60 foot can affect MPH, however I didn't think 4 to 5 mph.
On the way home Brad literally emails me and says, "DON'T DRIVE THE CAR HARD!" OOPS. He could see in the logs that something wrong and told me to check all of my boost reference hoses. He also saw the difference in boost.
Sure enough he was correct. I got home and yanked the cover, and there she was. A hose was detached. Why any line that sees boost that isn't properly secured (hose clamp, spring clamp, zip tie, bubble gum, super glue, Ford was stupid about this) is beyond me. I posted pictures. Long story short, the turbos were running away (over boosting). The computer sees this and actually closes the throttle to limit boost into the motor (Ford was smart about that). I fixed the line and now she is back to normal and now has the big end rush again.
At the track with the boost reference line issue the car was getting all the boost out off the launch. The computer saw this and started closing the throttle during the pass, so....maybe in January we will see a faster pass.
Long story short car went faster (not at 100%), check your boost reference line (clamp it down), and SENT IT!
Also my SHO at full weight (no weight reduction) with me in it (240 lbs) and a quarter tank of gas weighs 4560 lbs. So 4320 by herself.
Any thoughts about an upgraded rebuilt transmission?Interesting, sounds like mine.....
I have been diving into this. The snap ring on the direct drive for the 3rd gear/5th gear/reverse is know to just fall off. Also the "wavey discs" are know to snap in the same drive hub. We are taking it apart and figuring out how to proceed. Maybe there are somethings we can make better in house.Any thoughts about an upgraded rebuilt transmission?
Well hopefully it's not a horrible experience or expensive. I remember getting some quotes for mine when I thought the TC was going out. Tranny shop said about 1k for every gear our trannies have, so roughly 6k to rebuild it stouter, but really nothing out there for them.
Cheaper to replace it was the final thought.
Good luck and and keep us posted.
Sent from my LG-LS998 using Tapatalk
