HiThere's two types of Toyota mains, one with a single oil hole and ones with 3 oil holes. Not sure how to tell the difference between them. One set I had had 1 hole and one set had 3 holes. I wanted 3 holes in both of the end bearings so I just drilled 2 more holes in the end bearing that had a single hole. If you get two sets of the 3 hole bearings no drilling is required.
I can't find a lot of my pics for some reason, so the ones here show the single hole bearings. I ended up using the 3 hole ones though.
I was just looking the rod bearing and i was looking at the ford 2.0 or 2.3 liter duratec and they have the same journal diameter and the other spec are very very close did anyone has try some of those bearing?
