Top & Front 60k Service - Las Vegas
91 Vegas SHO
Las Vegas
Looking for a shop in the Las Vegas area that someone may know of that has experience working on Gen 1 or 2 SHO’s. Want a top and front 60k done and am assuming that any regular shop may not be able to handle? Any recommendations or referrals are appreciated.
I could be wrong, let me know if just a normal reputable shop can do this or if I should be doing this myself? How long would this take a relatively competent weekend car guy to do? Done a lot of work myself to fox body mustangs like clutches and bolt on mods but never worked with timing belts etc.
How many miles on this car? There is alot of how to info archived around. First time through you have budget in lots of extra time. the more times you go in, the faster you get.
blk\blk90
TX
I'd definitely schedule a weekend for your first one. But a reputable shop should be able to handle it if you let them know what it is and that it might be a bit different than normal service on a car.
Can you get to TX? Texan Tony might be a possibility? IDK if Scott Patterson has time :)
sperold
Last to Know
A member on this forum - Devin - had a website with a map of repair facilitie located across North America.
If the website is not active, he will still have the info, and he is located in the Pacific NW, so he may even have personal insight regarding your area.
91 Vegas SHO
Las Vegas
Thanks for the advise. I think I may just take my time and do it. It’s not a daily sooooo
91 Vegas SHO
Las Vegas
Awesome, thank you, will try and hit him up
91 Vegas SHO
Las Vegas
After reading reply’s and doing some research I’m gonna knock it over a weekend. Appreciate the feedback
If it's not a daily then for sure give it a go. Just be very careful with the bolts on the intake and valve covers. The aluminum is very soft and will shear the bolts or strip the threaded holes with too much torque. You have to snug stuff up without over tightening. Take your time and label/baggie stuff so you can keep from forgetting what goes where.
bmytych
