StealBlueSho
So I have been waiting to get my hands on one of these for QUITE some time. On my 2010 I ended up going with the Alky Kit to resolve fuel pressure issues since the HPFP upgrades were not available. However, on my ****** 2016 I decided to pull the trigger.
A BIG shout out to Cody over at LMS for answering my questions, putting up with my canceling, then calling back to place the order, and the 5 different tune revisions I asked for. Then for answering a couple quick questions for the installation.
Installation was super easy, if you follow my how to on the HPFP replacement, its pretty much spot on... a couple changes...
1: You will need to bend the high pressure fuel line SLIGHTLY up so it will line up with the new pump
2: The electrical plug needs to be unbound from the taped up wiring harness. This will include cutting back the tape to free up the plug so it can reach the new pump.
Those are the ONLY two differences between putting in a stock pump and the Firestorm pump. Silly easy..
Initial datalogging shows MUCH more stable fuel pressure, fuel pressure is holding desired where as before it was dropping well below 1000psi which is downright dangerous if sustain, which is was. The car drives really realy well.. smooth, pulls through the RPM range smooth.. very happy with this purchase and support from LMS.
