94 mtx no crank no start
Xavier Hoffman
Hey guys,
Recently, my 1994 Mtx began having a intermittent starting issue. Every once in a while, when turning the key, it would no crank no start. Lights would come on, fan, everything, but no cranking and from what I could hear, no solenoid on the starter, until randomly after a bit of time, it would decide to start for no reason (for example, today I was turning the key, and nothing, but then, the very next key turn started it with no protest from the engine or anything, like nothing had happened).
This happened every once in a blue moon, but recently, it's been happening every day, or even multiple times a day.
What do you guys think it is? I read somewhere it could be a bad wire to the starter, but I want to make sure, as I am quite new to the SHO. I'm pretty sure it's not battery as the car will eventually start after awhile.
KyngofPop
Freday-day
Charlotte NC
The fan comes on at koeo? Unless you have it wired that way that's a sign of a malfunctioning CCRM...not sure if it has anything to do with the starting issue tho
FreddyB aka Kyngofpop
Irish Pride
Irish Inside
MusicCityUSA
Where the F@#$ have you been?
KyngofPop
Freday-day
Charlotte NC
Away lol. I left FB quite sometime ago and had major surgery that I'm about 6mnts into the recovery period so blah lol. Totally missed all u guys tho, that's for sure. I'm trickling back into the SHO world my friend
Sorry for the thread hijack op
So the "no crank" condition is usually due to either a bad starter solenoid or a bad starter motor, but can also be caused by other obscure things like a bad ignition switch etc. Given your condition is getting steadily worse, it is most likely a starter/solenoid issue.
Off Road SHO
Moderator
Start at the device (the starter) and work towards the source (the battery) looking for +12 volts when the key is in the start position and the clutch is depressed. The path is: starter solenoid > clutch safety interupt switch > ignition/start switch on steering column by left knee > thick yellow wire > 60 amp fuse in engine compartment fuse box > Battery
Tom
