bpd1151
Lurking Around
Welcome aboard the METH Addiction Train!
Muahahahahahaha
Muahahahahahaha
Took back to stock tune, going to dealer in morning for routine checkup as bumper to bumper gets nearer @ 28k right now. Anything I should have them check, getting ptu fluid changed as a precaution.
Sent from my SM-G955U using Tapatalk
Took it out for a wash and came back and gave a it a Mothers California Gold Brazilian Carnauba Cleaner Wax Paste Shine
Finally found 100% Methanol within a reasonable drive.... so there for I felt compelled to ordered the LMS Alky Kit.... let the meth fun begin....
How does one go about seeking out a meth dealer?! Seriously, I'm real close to pulling the trigger also but have no clue where to buy "the stuff!" I know you can make your own with De-icer washer fluid and 2 cans of Heet! Not kidding at all! A friend owns a performance shop and has done this numerous times even with high-end performance vehicles with owner's permission of course and never an issue! Might go down that path if I have to!
+1 on the go kart drivers. I went to my local speed/performance shop and they sell it by the gallon. I simply bring in any container and they fill it up and charge based off how much I get.The guys I got it from said they sell it by the barrel load to the go kart competition drivers...
Per dealer it's water cooled and a bitch to do. Have to remove cat to get to the tempature sensor (fill plug). It has a drain plug. It's on record as wanting to change fluid so if anything happens he's going to hang it no questions asked. Turbos and everything else looked good.Turbos and PTU are at the top of the list.....
Thanks. Lmaoooo give me another 3weeks on the meth *twitches*scratches neck*. Congrates on your kit BTW. Hows it feel over the 4+x?Looks schweeeeeeet!!!! Where the Alky pump?!?!?
Sent from my Nexus 6 using Tapatalk
Judgment is still out.. LMS sent me a revised Alky tune... basically same boost/spark as the 4+X but less throttle control... I asked for more....we will see what they respond with...
It's a good all weather tune.... I wouldn't call it a balls out race tune though...
This Alky kit is quite impressive... the progressive controller is HIGHLY tune able.... Julio is awesome to talk with... if you had a tuner that was willing to go balls out with it... you could get into the 11's on a race tune with 100% meth... without the motor or turbos... but that MY opinion...
Man. I'm hopping for at least 12.2's with meth. I May have to just let them dyno tune it. But I want direct port before I dyno. You have dp's?
And I degreased, sanded, primed painted and clear coated the wheels last year. I need a tougher clear coat (maybe wheel specific). Its held up well but there are a few pebble chips.
