Ahrmadillo
Wisconsin
Not bad! Look up the cost/ETA of a new windshield in the meantime, and insist on OEM for, yes wait for it, durability. Non-OEMs are even worse. You will want the appropriate windshield for the options you have: rain-sensing/soundscreen/etc. Current availability can be a few weeks, as there seems to be a nationwide shortage. Also look into getting full coverage on your insurance for glass replacement. We have a few people in AZ & TX having to replace the glass every year due to damage from heavy flying objects/road debris.
just replaced my windshield a few weeks ago because it cracked from the top in the middle cost $400 for original replacement from my local shop and they got it the next day no backorder waiting
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
Not today but spent two days getting the "Summer coating" and Carlisle prep. Wash, Clay Bar, polish, glaze, sealant and good summer coating of wax. Even managed to Jetseal the glass. Next step is rest of glass, tires and interior. Getting a good set up for Carlisle and will be easier to maintain while on the road. Yes I will be bringing my buffer and detailing kit.
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Ok, washed twice, once carwash then hand wash. Then Klasse two step, Klasse All-In-One then Klasse sealant glaze. Let cure overnight. Next day wet towel then 2 coats Collinite 476s. This is the stuff the God's use to wax their cars! Love the stuff. Handwashed rims, let dry, then 3 coats Liquid Glass. Changed oil with Pennzoil Ultra Platinum, with motorcraft stock filter. Cleaned dry synthetic panel filter full of sand and leafs and bugs...car tinted rear and back with 5% lluminar nano ceramic. Front seat and front passenger with lluminar Air80 nano ceramic 70% tint. Full interior mini detail by self , vacuum rugs, treated seats with Porche leather seat conditioner. Re installed authentic RXP catch can system. Purchased from Crutchfield speakers using their techs recommendations, front and rear door speakers 5x7 Polk audio DB572's and rear back panel bass speakers Kickers DSC69304 6x9's, to be installed next week. Came with adapters for plug and play, and pdf file with complete instructions with pictures. Contemplating a Livernois Windstorm CAI and giving it the inside and outside heat deflecting insulation and proper hood seal if needed. Then just drive her!!
glockcoma
What? All that wax and glaze goodness an NO PICS????
Sgtmeatsauce1
2013 SHO +pp
New Jersey
I have tried twice can't get them to load....every picture says cannot download image too large.....
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Also need to replace drivers side mirror which has blindspot and heater mirror. It has turned all black-delaminated. I searched all over, they are about 300 bucks for a mirror! I fought with Ford CPO bumper to bumper warranty, apparently a mirror even though a safety issue is not covered by bumper to bumper warranty!
marius883
Orlando, FL
One of the dealers I took mine to gave me a hard time over the instrument panel which had bubbles on the inside. Said it was not covered under CPO warranty.
Took it to another dealer, they replaced it, no questions asked (just $100 deductible).
iman2408
Unfortunately I have to get rid of the SHO, insurance is just eating me up in Michigan. New job can't afford the car payments anymore.
2011TAURUSSEL
DFW Metroplex, USA
Started loading for Carlisle. Will load and keep in garage for now. Need to make a trip to local tire Nitrogen Octopus pump and get all tires set to 36 PSI for trip. Two storage totes in trunk. One for detailing supplies, one for everything else. I don't mess around on road trips I bring extra detailing supplies W/S washer fluid, basic supplies. Fuel top off for departure and on my way.
StealBlueSho
NA
B72ea53d913a3e4494bd2aed50d1cac5
It begins!!!!!! A little oil in the pipe going to the TB... none puddled in the TB so... good to go! PTU looks clean with no leaks... oil return lines to the Turbos have a small amount of residue... probably try to replace those (again...)
Now for FedEx to show up with my ****....
Lostneye
NY
Had a stereo install recently with custom sail panels tweeters. About a week later the factory grill was driving me crazy aesthetically. Sent my a pillars off to my installer to fill in the grills and wrap in alcantara. Just got them back today, went out to the parking lot at work and installed them. Very happy with the the results.
2011TAURUSSEL
DFW Metroplex, USA
Yesterday did my Pre Carlisle top off fuel and Nitrogen at Costco. I inflated to 40 PSI and will bring down after the tires cool usually overnight. Loading in progress and I also got a quick shake down cruise yesterday.
StealBlueSho
NA
Completely finished with Alky Kit Installation... tune(working on it..) and all....
Thanks to BPD1151 for the Alky How To installation guide, lots of good information.. such as which wire to tap for the MAP sensor and which fuse to piggy back off of on the fuse box.
Couple things to note...
1: The instructions recommend loctite for the nozzle fittings... I would recommend white plumbers tape.. the loctite leaked...
2: If you plan on using the supplied tanks for the windshield washer reservoir, make sure you cut the hole for the pump perfectly round.. or as close as you can get... mine leaked cause I screwed it up...
3: Going through the firewall, BPD's directions are pretty solid, but make sure you use at least a 1/2in drill bit, and make sure you go straight and as close as you can to the blue tab in his picture.
4: When testing the alky, it might take a bit longer than you would think for all the air to get out of the system and the ready light to go green..
5: If you buy a 5 gallon can of VP-M1, unless you are going to transfer it to a different contain... get some kind of pump to get it out with... crap goes everywhere even if you are a brain surgeon...
Initial datalogging is showing a significant decrease in IAT's.. over 30F drop... Current "Meth" tune from LMS has no added spark or boost, I have an email out to verify if that is correct. Car runs like champ though.
