Tune top end question
DerricksSHO
Michigan
Those of you that are tuned with mods what kinda MPH have you been up to? I was roll racing a friend a mine in his little tuner honda N/A and it is like my car is hitting a brick wall about 130 135.... was woundering if different tunners had different top end strategy im working with Torrie right now. Thanks guys
Sholab1
United States
140 outside Lexington, still had more to give. Torrie's 93 octane tune. 3bar, plugs, t-stat.
Sent from my SM-T560NU using Tapatalk
Adam Dutcher
DUTCH11SHO
Newport News, VA
140mph+ with LMS 93 4x-race tune and every bolt on you can think of, I95 VA heading towards DC. Racing Nissan 370 I was pegged out at 140mph b/c that is the highest our car reads and I was still pulling away from him real speed TBT. 2011 SHO PP.
gimpy
Pennsylvania
Roll race an SHO, why?
Right off the bat you take away it's advantage. Not only that, but it's weight comes into play after about the 80mph mark.
Adam Dutcher
DUTCH11SHO
Newport News, VA
Yes stock is limited to 135mph. No tuner can turn off the limiter but they can raise it to a crazy number that the car will never achieve. Like I believe LMS raise's it to like around 200mph. If wrong please correct me
DerricksSHO
Michigan
Yes im not usually a roll racer but being a street guy a you go where the fun is and the challenge was at the time. Ill have to data log some more when it gets warmer out and see what Torrie can do the car has all the bolt ons you can do minus water/meth.
mrhighcaliber
Top speed: 161mph, GPS confirmed. (Car's speedo reads abt 2-3mph higher.) Lms 4+x, catless dp's, 3bar, pp suspension, hr springs.
Sent from my Nexus 6 using Tapatalk
Will still take a while to actually reach top end :D so be patient! Ask to borrow bpd's SHO to feel the POWAH!
OmaHahn
Omaha
LMS tune and been to the 140+ territory very quickly and still pulling! Roll racing is OK in the SHO, just as long as your in 1st or even 2nd gear! I've still dusted other respectable sports cars from a 1st and 2nd start!! :burnout:
Boosted Sho
DerricksSHO
Michigan
yeah put the car up against its first good dig race of the year friends 2002 ss camaro did good he got me by half car his car has some work done to it on slicks so I like the direction the car is going.
Jeff2017
I would think the weight is has bigger effect from a stand still(i.e. inertia) and at speed, aerodynamics become more important. These are
big cars(i.e. move a lot of air out of the way).
StealBlueSho
NA
AWD cars are quick 0-60 cause you generally don't have traction issues from a dig.
RWD/FWD cars have a hard time getting the power to the ground and moving. Especially something with enough balls to keep up with the SHO...
Hence why you never(almost) see AWD cars with slicks at the track.
gimpy
Pennsylvania
Are you sure about that?
Seems to me it takes a heavily modified car (sometimes with slicks) to be ahead of me after the 660 mark.
I'm not saying an SHO is king of the streets when it comes to an 1/8 mile sprint, but I am saying that not many cars got the better of my 11' in that sense.
Jeff2017
No, I am not sure at all. I guess the AWD drive overcomes some of the disadvantage of the extra weight sense you can essentially floor it and it will keep traction.
