Who has B&G Lowering Springs
MondoSho
What shocks did you use? It looks great, also is therevanything else that is recommended when lowering a sho?
I was runing full stock setup in rear with the b&g had 2degress of camber. So if you can get the eccentric bushings you should b able to have it aligne extremely close.
MondoSho
Also will these fit with factory spec tires? I just got a brand mew set
LOUDSHO92
Rancho Cucamonga, CA
What shocks should I use? Can i just get a package put together springs, shocks and control arms?
Monreo struts are the best option we have right now. We have not made a package on sruts and springs due to a lot of variables.
Yes.
shobroooo
