Noise maker elimination
BlueSHO
I used a Dremel to trim the narrow end of the outlet off, then the cap fits perfectly and has a lip to seal on.
I might have done that but I didn't want to grind on the stock piece.
Sent from my DROID RAZR HD using Tapatalk
BlueSHO
Other end you left open and just hanging there?
If this question is for me no I didn't and that was just for what the noise maker looks like removed
Sgtmeatsauce1
2013 SHO +pp
New Jersey
OK was not sure maybe it went no where and had no bearing but looked like had a vacuum line on it, thanks
BlueSHO
Just an update here. Went to full boost yesterday and heard a fluttering sound and power fell way off. Popped the hood and the cap had blown off the inlet tube. Found it laying on the engine belly pan. Noise maker is back on.
13blacksho
Des Moines IA
Same happened to me, so it cut the narrow end of the pipe off and scuffed up the wide opening with a Dremel sander and now it bites real nice!!!
BlueSHO
Might try to score a MKS inlet tube..
mmh64
crown point indiana
Was checking mine this morning. The cap still tight. No leaks there but found a boost leak on the underside at OEM rubber to hard plastic connection. These two peices rotate freely when I twist them in opposite directions. There is no way to tightened the plastic clamp that holds them together.
20160704 090057 zpsaejtlzpd
OEM failure. Looks like I will be shopping for a new part. Without the noise maker opening of course.
BlueSHO
Good find. Let us know if you find something
BlueSHO
Did a quick fix for now. Replaced plastic clamp with hose clamp. I may still shop for something else but for now I'm running like this.
20160704 102326 zpsolgbrfsh
What about that upstream clamp type contraption thing?
mmh64
crown point indiana
That is a hose clamp with a clip on it to hold it in place. Wish they used that on all areas. No failure with that. I left it alone. The vulcanized plastic clamp was the failure. Split it in half and peeled it off.
mmh64
crown point indiana
It's ovious to me this entire part is prone to failure. The other plastic clamp down lower I will keep an eye on. I can fix that leak if it happens. Eventually with high heat and prolonged exposure to CAC sludge the rubber parts will swell and degrade. I won't replace it with OEM. Needs to be all metal or similar plastic to OEM. Couplings of silicone. Aftermarket charge pipe is the only replacement I will consider other than building my own.
Roger Batts
Dallas/Ft Worth Area
I realize I'm reviving an old post. Coming from the ST scene, this part is called a sound symposer. On the Focus ST, it was a tube and electric valve that ran from the intake manifold to the firewall, but it served the same purpose: to pump engine noise into the passenger cabin area. I will definitely be looking to get the Interceptor/Lincoln tube to keep the lines clean under the hood.
Wbaubl1
Digging this back up. Has anyone figured something out that reliably works, besides the $150-$180 pile?
