Lost at the track ordered down pipes
yo tony
Manning, SC
well I lost at the track to a supercharged 05 cts v by 1.5 cars. Hope downpipes will make that up. Anybody running unleashed downpipes?
OmaHahn
Omaha
Downpipes is not going to make up that big of a difference! Maybe that with full exhaust and upgraded turbos & meth then you'll probably tie or maybe edge out that CTS.
yo tony
Manning, SC
Everything was untimed he did tell me his sixty was a 1.79 which I can't touch. His shifting left a little to be desired. He said he generally runs 8.20's. We ran one more time but he red lighted and I cut .140 light and he got me by about the same. I think I ran 8.41 at 82.6 on the clean one. We both had similar rts. Mods are unleashed 3 bar 170 tstat and drop in air filter and plugs of course. Downpipes on the way from torrie. I'm really hoped the downpipes help to get the 60s down to a 1.85 range
yo tony
Manning, SC
1/8 mile track. He only got me by 1.5 cars and typically runs 8.20sNo chance in **** against him 1/4 mile.his midrange was unimpressive. So what I'm asking is can I hope to gain 2 tenths from the downpipes.
BigB15
GA
You can touch those 60's
And you can run 8.20s
I have a unleashed tune, 3Bar and K&n, Tstat
12499
brucelinc
Yo Tony, my 60 is not quite as good as yours but my 1/8 is better. My car is a Lincoln MKS which is even a bit heavier than your SHO. Have you sent any logs to Torrie so he can tweak your tune? I think there is more potential with your tune. My tune is from Livernois but I know there are some quick Torrie tuned SHOs after some data logging.
77166e3e ad6b 4496 bb2a 655a8a57c2fd zpspracvpcp
SilverSH0
+1 here. Look at the trap speed of the OP vs other slips, 82 mph vs 85 mph. Clearly his car isn't running as hard as the other vehicles as those speeds should be much closer if his car was running as hard as the others.
yo tony
Manning, SC
i haven't. I was going to wait until downpipes were installed. South carolina heat and humidity is rough in the times
brucelinc
Yes, heat and humidity are not your friends at the track. However, I have no doubt that Torrie can find you another 2 tenths.
yo tony
Manning, SC
Alright so I couldn't hold out on the downpipes , just got a new tune from torrie and man what a difference. Can't wait till Sunday.
SHOnUup4
SE MI
Torrie is quite familiar with tuning for an e/85 mix too...that little mix could be worth a couple tenths.
I run sub 8 second 1/8 miles all the time...I definitely think it's in there
13blacksho
Des Moines IA
SHOnUUp4,
Since you brought up that E85 mix last year I have been doing it every fill.
But I was unaware Torrie can tune for that! I know Livernois is against the use of a drop of E85 but my car runs fantastic with it!!!
Any idea why they don't advise this?
I'm going to do some data logging next week and send it to Torrie, and with this knowledge I guess I should mention the fuel blend too.
Let's hope for some solid results!
SHOnUup4
SE MI
SHOnUUp4,
My guess would be...that our systems aren't designed for the corrosive attributes that come with e/85 and the inconsistent supplies of it at the stations (varying levels).
Livernois Motorsports
SHOForumSponsor
Dearborn Heights, MI
The answer is simple. The EcoBoost is already a fuel starved platform. Using a fuel that is ~40% less volumetrically is only going to exacerbate that deficiency. Why add insult to injury by using a fuel that we have proven can lead to failure? Your vehicle is not a flex fuel capable vehicle. So, there is nothing inside your vehicle or its fuel system that is rated to store or flow such a corrosive material.
gimpy
Pennsylvania
You're going to need more than DPs to make up one and a half car lengths.
However, hanging with (or beating) a V-series of either generation is nothing to sneeze at for any type of vehicle. Let alone a 4500lb, 6 cylinder family sedan.
shobroooo
