Blower motor won't turn off and only blows on high
tery
Silvia survived the purge- summer car
minnesnowta
Has anyone had this problem yet? I have a 93 sho with 3.2. Could a bad resistor assembly cause that? I hope not...they want over 200 bucks for it. Or is it maybe just the switch in the eatc,...of which a new one is on the way.
THoughts??
tks,
Terry
sperold
Last to Know
Start with the resistor assembly and get one on this forum in the "Parts Wanted" section. They are usually under $50.00 shipped. That will cure the "only works on high" issue, the "won't shut off" part is not a sure thing with this fix, but probably it will cure it.
hawkeye18
Sorta cares
Norfolk, VA
The SHOs don't have a resistor pack - they have a Blower Control Module (BCM), and there's a relay that goes bad in there and causes what you are describing to happen. You need to find a replacement one of those.
SHOtimer
#2910
Santa Clarita, Ca
Some folks have been able to repair it, but you have to be very delicate and find the exact circuit on the board that is bad. A lot of work.
Easier to find a good BCM in a junkyard.
It is under the dash/glovebox area.
Doug
I am pretty sure I still have one of those bcm in my for-sale thread. pm me if interested and I'll confirm.
NOTAURIUS
This is a strange problem. My 91 was doing this for a couple days earlier in the week but has now stopped.
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
Interesting. I pulled the fuse for now. Maybe some moisture go into the module causing it to stick on. It has been dry for 2 days so far. maybe I will leave it and see what happens.
thegreatbriguy
Carlisle
your stuck in eatc test mode. there is a combination of buttons to get out of it or if that doesn't work complete battery disconnection and drain fixed mine.
thegreatbriguy
Carlisle
Ok, so I have to retract my statement. My 94 did this today. Wouldn't turn off and stuck on high fan.
I put in a blower resister and it fixed it. I would offer one for being wrong but that was my last used one. Used to have a box full. Sorry
Devin
3.Slow
Pacific Northwest
I know this thread was necro'd, but someone else was interested in the issue, so for reference, the BCM is the module with the white sticker under the stack of connectors:
(click for an exploded view)
WatchTheSHO
Is it still available? I have the same exact issue with the blower turning on high seconds after car is started and it doesn't stop. Would a new climate control head unit do the trick? Or is it specifically the BCM and only the BCM that will do the trick?
313tiger
