Blower motor suddenly stopped turning on
Laser411
So my blower motor has suddenly stopped working, no noises or anything. Worked perfectly and now just does nothing.
I checked the PIDs from the hvac module and it's getting commanded to turn on and the module is not throwing any codes.
What should I look for and does anyone have a wiring diagram?
Laser411
Thank you for that, I checked the fuses and relays and they were good, then I pulled the cover and pulled the blower connector off and checked it and it had power.....then I plugged it in and it was working. So I am chalking this up to a bad seating of the connector, it didn't seem loose but no amount of wiggling made it quit working again. I applied some dielectric grease to the connector and slapped it back on. :shrug:
Jordan_R
Missouri
If the motor is going bad and you do find yourself in need of a replacement I have one out of my car I'd let go.
