Timing cover gaskets
shoftw
Does anybody know where to find gasket for the timing cover? Mines leaking pretty good and i would like to replace mine while the motor is out. Also like to replace the ac compressor clutch( ac gets warm after 20 min of operation) but i dont think their are any more replacement clutches available .
GEN 3 SHO FAN
Canada
When you say timing cover you talk about valve covers (2) or the front cover on the belt side (1) ? I found gasket for valve covers recently. You make a search on e-bay and company specialized in buying old new parts from Ford dealerships but when I called at Ford they said they still have some for each side (at least here in Canada, probably at Toronto for 60$ can.). I don't know the situation for the front cover gasket. If you're doing valve covers gasket, I suggest you to replace the seals of the plug well. Mines begun to leaking on the plugs when I remove valve cover... (Ford still have them too for maybe less than 10$ each and they are a bit harder to find on the net.)
You can find an old a/c compressor on e-bay around 225-300 $ If you have the Ford part number, google it and you can find some others place to buy it. I never saw separate parts for it on the net.
Good luck,
LOUDSHO92
Rancho Cucamonga, CA
We might be able to get a new clutch for $260 shipped. It would only be warrantied for fitments and not for defects. Our supplier stopped selling clutches because the defect ratio was too high. The majority of the time they went bad because the compressors themselves were going bad and were taking out the clutches.
We do offer new Compressors at SHO Source.
shoftw
I already have valve cover gaskets im looking for timing cover gasket(front cover on the belt side). Nobody still sell these? If i can't get the gasket is my only option is to rtv it?
shoftw
NAPA - #18757 - Timing Cover Seal - $10.04.
I need Timing Cover Gaskets ( their are 3 of them,front left,center,front right) not the seal. I hate to rtv it( rather have new gaskets, makes things less complicated) but has anybody ever done that before?
shoftw
Found the ac clutch but looks like timing cover gaskets is mia. After looking at a diagram of the timing cover gaskets for the volvo v8 i wonder if i can modify them to fit my car?
GEN 3 SHO FAN
Canada
For the spark plug seals, not so hard to find, Ebay or Ford vintage parts have them too (7-8$ each.).
98SF19
AlphaKennyBuddy
Florida
Wow, they really are vintage - not even a website! Thought you may have been referring to ebay so I searched there. Nope.
Can you give me some help on finding this "Ford Vintage Parts" source you mention?
Thanks!
