clicking noise in heat/ac vents
hoofbeat
in.
o.k. guys need a little help.I have a 2010 SHO with 17,500 miles on it ,has been a great car.A couple of days ago when i left home and turned on the outside air thru the vents there was a series of clicks (6 or 7 ) before the fan kicked on . Everything was normal after that.Sounds like a gear slipping trying to adjust the flow of air into the cabin??
Blend door problem most likely. Which side was it coming from? The passenger side blend door is much easier to replace than the driver's side.
hoofbeat
in.
update
:thankyou:I want to thank jmr061and shodded for their help. I called Ford and they wanted $40.00 for the part and $95.00 labor (min one hr) .Purchased the part from Rock Auto for $20.00 including shipping and spent about 10 min.on the install.Again thanks to you guys for your help.
313tiger
