Jim, how did you get the heater core out? Did you pull the dashboard out?Thanks for the info.
Problem I have is the driver's side door was replaced and the decal is not there. I know it's an early '89 though.
You know, it's occurred to me that since the leaks are always at the bottom of the heater core, that there might be a way to plug it.
HVAC parts for these cars are super inexpensive these days and when done, the entire climate system will be brand new. Bought a new Motorcraft condensor for $40.00, the accumulator with suction hose for $30.00, and the liquid line for $20.00. Going to go ahead and convert over to R134 and be done with it. The compressor is fine except it needs a new clutch but I'm debating on whether to just go ahead and buy a re-manufactured compressor instead because it and the cost of a clutch are about the same.
jimtash, where did you find the Motorcraft condensor? Everything I'm seeing is double that price. TIA
