Looks awesome! Did you use the engine harness for the injectors as is or are you making a new one?
The craftmanship just awesome. Love you idea. Only thought I have and you know your type car more than me. Is that area a negative pressure air because of air flow of roof or is pressurized? I just don't know. Keep up the pictures and info. Maurice
Don't ask me how I know this, but make sure there is enough distance in front of the metering tube of the MAF sensor to get nice laminar flow of air. If there is a bend near the meter's hot wire, the air "burbbles" across the hot wire and doesn't cool the wire. The PCM interprets this as much less air is going into the intake than is the case.
I fixed one of my SHO buggy buddies car just by getting rid of a sharp bend near the MAF intake side.
Tom
Which maf are you using?
If near a bend, the MAF should be on the outside of the track, where the air has to take the longest path. Air does the same thing that water does in a bend, the faster water is on the outside of the bend. If the bend is sharp enough the water or air on the tight side will form eddy currents and whirlpools ( also known as burbbling) in the short radius side of the bend.
Tom
