Ruckusnuts
Hey everyone, I'm a newbie to SHO's. Just picked one up for a winter car and am trying to get it running right.
Trying to troubleshoot my rough running 95 MTX. I found this just hanging out in the engine bay. http://i.imgur.com/iARImgi.jpg
Also I'm throwing 112 and 212 codes. Any pointers? Thanks everyone!
Symptoms: No power and and stumbles and misses at Idle. Pretty sure it's not firing on all holes. I did a KOER Balance test and it flashed 9 as OK. It also didn't sound like one cylinder was worse than the other.
So far: Fuel pressure is a weak on the top end. 32lbs It has a new pump so I'm ordering a regulator as I smelled gas in the vacuum line where it connects.
Compression is 125lbs +/- 2% across all six
TPS voltages are good.
Cleaned the MAF
Secondaries open at 4k
Daylight through air filter
Plugs look new, but am ordering new wires. Tested a new coil but no change.
Also found an unshielded wire in a frayed loom behind the Intake manifold ground strap. It still has continuity to ground but it looks bad. I'm tearing into it momentarily. Here it is http://i.imgur.com/DwJ0Qxz.jpg WTF? Is it supposed to be bare? It doesn't look like it ever had plastic around it
Any ideas or tips. Thanks everyone!
Cleaned the MAF
