Restoring a 1993 MTX
SHOVNST
Blood type: SHO+
Niwot, CO
I can see 16mpg if that is mostly city driving. Some V6/ATXs can be guzzlers, and for many reasons. For reference my `92 MTX SHO get 22-24 city/30-31 highway (averaging 70-75mph) and I would not be considered 'easy on the throttle'.
Do all 3.0 SHO's feel really soft until above 4K?
Yes, but more with the auto trans.
Macgyver
New Jersey
Wow, I drive a mix, but nothing that would be considered city driving. I drive 9 miles to work on winding country roads, and occasionally on the highway but not really above 65 or 70. I don't have any codes, but I plan to check the fuel pressure and TPS next. When my other car averages 27 mpg on a long trip and this car can't even approach that, there has to be a problem. That car is heavier, likely has little aerodynamic advantage and has twice the displacement.
Macgyver
New Jersey
OK, If I can't get some decent mileage this weekend, I'm gonna take 4door4sho'S advice and start a new thread regarding mileage. I will be driving from my home in South Jersey to Quakertown, PA this Sunday for a softball tournament with my daughter. My V will approach 27 MPG average on this trip @ a steady 65 on cruise. I have seen 26.9-I've also seen 9 running it hard. I hope this car will do close to that. I don't think 9 is even possible in a stock SHO without a fuel leak.
SHOVNST
Blood type: SHO+
Niwot, CO
If possible: Use a GPS for mileage calculations. Fill up gas tank pre and post trip as identical as possible regarding the nozzle position when fueling. Set tires to correct PSI. All of this will give you the most accurate reading. Safe traveling!
kevinspann
Don't take my advice.
Richmond VA
That sounds about right, factors being speeds/traffic and fuel (E10 I assume).
Macgyver
New Jersey
OK, Here's a question directly related to this resto project. I ordered rod bearings and gaskets-the kit from RCM last week-and have yet to get a response. They have received my money from PayPal. I have received no confirmation of payment and no shipping/tracking info. Does anyone here have recent experience? Please don't reply "Search the forum". If I needed old info I'd do just that.
I have occassionally had delays in orders with RCM, but usually a followup EMail or two has brought about a quick resolution. I hope that will be the case here as well.
b1lk1
Acton, Ontario
Damn, just started tearing down my 94 and it's from the rust belt and it sure has alot of rust, and in some bad places too. Aprons around strut towers, both rockers, drivers door, other places need patches. I have too much $$$ into it to crush it, it's hardly worth the trouble otherwise. Sure wish I had your rust problems, lol.
Macgyver
New Jersey
Yeah, I'm very lucky. I did a great deal of rustproofing while I had it apart for paint. The backs of the fender, inside bottoms of the doors and doglegs got rubberized undercoating. I tinted rustoleum to get a close match and did the gutters in the trunk. It is a very clean car. It's a bummer that the passenger floor will require repair, but it's in an area where they all rust no matter what. It will be repaired properly with longevity in mind. Good luck with yours. They are fun cars.
Macgyver
New Jersey
Rod Bearings
I decided to do the rod bearings before I put too many miles on it. It had the telltale 1 second start up clatter, so I knew it was time. Everything went perfectly. I griped a bit about RCM, but they came through with everything I needed at a very fair price.
The old bearings were worn to the copper, but nothing was scored or beat up in any way.
20130622 135527 zps62709ccd
20130622 150110 zps9c112635
20130622 141446 zpsce7dc4c4
Macgyver
New Jersey
I've been driving that car for a couple of days now and I have to say I'm very happy with the outcome. Thank you to everyone for your support and advice. I hope my documentation of the process helps others with their projects.
Macgyver
New Jersey
The car is going to a very happy new owner this weekend. I trust he'll be an active member on here. He is a long time Ford guy and has an appreciation for what these cars are.
