How to install NITROUS???
tizzem
tac
I have a zex kit and I'm stumped on how to install it. I can't find clear directions anywhere. I got the kit used, has everything except the purple box (has a switch though)
If anyone in washington want's to assist me in installing this I'd be glad to pay.
SHOspazz92
Banned
Triad Area, North Carolina.
The purple box is the NMU, You kind of need that. What model Kit is it?
The Zex kit of Choice for the SHO is the Dry Kit 82011. You'll need to change your plugs as well with ones that are one heat range colder. Autolite 3923's will do fine.
Have you tried using the Search function on this forum?
-Sam
gmail
Well-Known Member
sunbury pa
yeah you should be able to find something using search or their website...
if i recall its 1 wire for the tps and power for the system then tap your line to the intake tube. the rest should be easy.
you do need the box!!!
AREA 91
Area 91
Please do a search.
There is plenty of info on this forum.
You can even search under my user name for the info.
:wave:
matasho
bigshotsho93
Beloit Wisconsin
You need to use the search function. I posted very detailed instructions a few years ago when i installed a Zex kit. My instructions and Zex instructions.
