javve
SHO Lovin' It
I have been going through possible causes to try and find the problem. I have to change my fuel pressure regulator and plan to do the fuel damper as well since I am doing the one. Went to swap out the pressure regulator with one from the junk yard that looked a lot better, now leaking fuel from that area. I am suspecting bad washers. Does a new one come with washers?
Here is what I know so far.
Charging system and battery are fine.
90 degree plus temperatures here
Engine bay is hot hot hot
Unable to touch coil pack for any length of time (swapped with one from the JY off a 95 ATX sho)
Car starts and runs fine cold, but will die while running or driving down the road when the car reaches normal running temp.
Does not always happen when it's hot out, so it isn't a constant get hot then it dies.
When it does die, it acts like it will start but barely reaches 500 rpm before dieing again. If I turn the key off and on a few times, it will reach 1100ish rpm then die (Fuel pressure problem?)
Let it sit for a few, it will start up. Sometimes it will die right away, other times it will be fine.
Car sat while in part store to check the charging system. When I went to start it it got the bad idle after a couple minutes then died. It had sat for roughly ten to fifteen minutes.
I am not able to test fuel pressure right now until I fix the fuel leaking problem around the pressure regulator.
