Engine Vin Number
Aqua Roach
Deadly Insane
Concord, NC
Hi, I was wondering if there is a vin number on the engine of the SHO itself, and where it's located at. I have a 1995 SHO ATX, and after pulling it I'm having rising suspicion that it might not be the original motor. [May even be a 3.0 bolted to a ATX Tranny]
Any help is appreciated!
Racer X
SHO Pilot, Retired
Connecticut
The engines don't have a matching VIN number that I know of.
How does your coil pack sit? Does it sit level, or is it canted forward towards the radiator?
jelloslug
Digital
Greenville, SC
The only real way to tell the difference between a 3.0 and a 3.2 is to look at the ribs on the outside of the engine block. The 3.2 has more of them.
Aqua Roach
Deadly Insane
Concord, NC
It sits more tilted towards the front.
Well since I don't have a 3.0 to compare too, :p, is there a way to get an exact number to count?
Thanks for the replys!
jelloslug
Digital
Greenville, SC
Here is the underside of a 3.0:
Block20120 20Copy
If there are more ribs around the freeze plug areas it's a 3.2.
jimtash
nc
There are numbers on the underside of the block next to the oil return hole that I am guessing show the displacement. Have a 3.2L block on an engine stand and it has 3322 stamped on in.
Aqua Roach
Deadly Insane
Concord, NC
All I wanted to hear. It's sitting outside of the car ready to be rebuilt, got a good little project going on. :D
Thanks guys! I'll bother y'all with anymore questions I got for this bad girl!
well then, you will know for certain as soon as you pull off the first head and can measure the piston diameter!
