'89 Steering Wheel Pad Question
RonPorter
SHO Club of America
Lake Orion, MI
Need to get the '89 back from KY, and when I do, I have another '89 steering wheel to swap in.
Anyway, the current wheel pad is dented in, as many are. Probably from an over-anxious horn blowing at some point!
Is there a good way to safely flatten it out again so it is at least close to the original look? Any tips/tricks?
mrecoolgar
SHO NUP
Hershey-PA
I had the same problem with my first 89.
I disassembled it to the metal and pressed it back to normal.
JRA2000TL
The Complainer
Daphne, AL
Ron, I have a spare one that's not dented in. I'm super picky about stuff as most of you know, and the rubber cover part had a stain on mine that I could not remove. I picked up a junkyard one, swapped the rubber cover, but still have the metal frame that the padding goes on. I have no use for it if you can't get yours fixed to your satisfaction. Let me know. (No this is not a for sale ad, he can have it for shipping cost only).
Be careful though, when I swapped mine out, I inherited a problem of the horn chirping when I turn the wheel. After checking all the connections/contacts to ensure they weren't getting pinched, I still am having the issue.
jelloslug
Digital
Greenville, SC
There are some spots that are supposed to have some tape on them near where the screws go through.
JRA2000TL
The Complainer
Daphne, AL
Yeah, I saw some clear plastic tape/tab things around that area. I think they're bent/angled because I compared the 2 I had to make sure they were put back together the same way. I'll have to re-check it again sometime.
shobroooo
