SHOMurph
Ford B@stard
I'm wanna play tooooooo
N/A then spray........and a slushy ATX also.
Thats the absolute worst comparison as far as Sho's go. First of all, your car weighs nothing (for a sho). Second, you have the gen3 subframe. Third, you both are running coilovers, which are not setup for drag racing. For a FWD drag car the front springs should be short and light. The rear springs should be tall and as stiff as possible.
Slicks on a car that is setup correctly will always hook better than a DR. Of course Brian is breaking axles, hes running the g1 subframe and dumping the clutch. You pull a 1.9 on drag radials, Ill give you a dollar![]()
Actually the fastest that we all actually saw the timeslip for was Nik97 which was a 12.72
I think that slip got lost between the other two owners.
Both of you guys need to do your research on the cable mod and get some REAL slicks. Drag radials just dont cut it.
Josh T(Shonut), Brian(Area91), and Alex(somedude001) all had slicks and ran 12s. Theres more im forgetting too. Alex doesnt really count because of the atx.
As far as I know Brian is the only mtx guy running a faster 60ft than I did and he runs slicks.
PS I ran 2.0 flat, just looked at the slip a few days ago.
I don't think its fair to say at this point that slicks is whats going to get every high horsepower SHO in to the 11's.
-Sam
After seeing him come to indy, and watching that thing.....if you think he isn't onto something, you're a fool......I'm in agreement with murph...(somedude001)Alex doesnt really count because of the atx..
slowWhat is the GEN 3 record???
think the problem with the lack there of more 12 second cars is that we've been trying to launch more manual transmission cars than automatics.......
hmmmmmmmmm think somedude might have been ahead of his time.....or all of us wayyyy behind.
p.s. I disagree.......
slowbut to be honest, I've never really seen any g3's with power post times
That ATX, wasn't that the pink ATX trans? If so, it is now in Whiteguy's (Scott) car.
Heres my ideal setup
Gutted gen2 (I think the drag coefficient is better)
6in 250 lb front springs
14in 650lb rear springs
15in MT slicks (small gen2 brakes)
tiny ass rear wheels and tires
3.2 forged stock compression
Precision 6765 billet turbo
3.5in downpipe to a dump
gen3 subframe
no front swaybar
quaife (needed to heat up both tires)
stock shifter
Thats an 11 sec pass.
