You should Offer them to me.
You are not worthy...............................................yet....
You didnt offer them to me!![]()
Just kidding.
Well Evan will make it out to the track before me but im not too far behind. The car should be together in 2 weeks at the most. O and Brain, slicks please![]()
I would suggest trying sticky street tires (like RS3s, for example) or DRs first.
To make slicks work properly is a whole different dynamic. Plus, you need to bring spare axles along as maintenance items.
Work on the "driver mod" with DRs or good stickies first. Then tackle the learning curve to make slicks work.
Slicks are not an immediate cure of anything. For example, on the street, pure slicks would be worse than DRs or other good summer tires.
Well after managing consistent 60ft times on just plain bridgestone summer tires i think i could be ready to learn how to use slicks. But i will only go to slicks if i cant run faster than a 13.8 all motor on street tires. From what i hear slicks are less Damaging on axles than slicks but never experienced this. Also ill be on a g3 subframe and from what shoamo says helps a lot.
You may be driving well for you limited experience, but not enough yet.
The comment about slicks is pure BS. If that was the case, why would ANYONE run slicks over DRs?????????
Slicks give you better 60' times. That is harder on EVERYTHING!!!!
If slicks were easier on axles, he wasn't doing it right. DRs have gotten RWD cars into the 9s (the last I recall....maybe better today??) but those are RWD cars.
Slicks work better.....when properly prepared.....which means that ALL engine/drivetrain components are more stressed.
People have run 8's on DR's!
-Sam
Then we have Mark N's gutted Nitrous car, that ran the same quick time hossiers that Brian does...that car could only do 12.90's. Obviously, the DR cars have outran the cars on slicks by quite a big margin at this point.
So do you think no lift shifting helped you get there? I have never tried to no lift shift.
