JRA2000TL
The Complainer
Should I replace the bushing since it's the white factory one still that's 22 years old? Is it difficult to do?
I've followed this post and I suspect that you won't lick this thing until you:
1. Replace all four sub frame bushings.
2. Replace the rear motor mount.
3. Replace the clutch cable and bushing. Use the SHO Source bushing.
4. Replace all the front strut bushings. Use the polyurethane pieces from MOOG. Check and or replace all the rear bushings as well.
5. Check your shifter for play. Clutch is probably going south by now also.
6. Do all the routine maintenance as required.
Sounds as though the previous owner did nothing and waited for you to buy it. These cars are expensive and need proper care or they become a PITA. If you get in an accident with this thing in its present condition it will be way more expensive.
:swing:
With the clutch engaged (pedal up), this bushing isn't gonig to affect a thing.
